will not burn at end of conversion
I have just updated to the latest beta 1.4.0.0,and after conversion the program will just sit there and not burn the disk as it is supposed to.i tried the conversion twice with no luck.i have included the 2 log files for information.
Renits
Renits
- VSO Video Converter 1_crashlog_.20140615.125526.786.log
- (6.11 KiB) Downloaded 415 times
- VSO Video Converter 1_mainlog_.20140615.125516.863.log
- (6.2 KiB) Downloaded 411 times
Re: will not burn at end of conversion
Hello renits,
Thank you for your report!
Bug reproduced and fixed:
http://bugs.vso-software.fr/view.php?id=8087
Just updated to beta 1.4.0.2 and tried again with my custom settings and the drop down predefined settings,both times the file converted and the burn process did not work at all.
I have posted both sets of logs.
Renits
Renits
- VSO Video Converter 1_crashlog_.20140618.161204.443.log
- (5.11 KiB) Downloaded 428 times
- VSO Video Converter 1_crashlog_.20140618.122322.777.log
- (5.25 KiB) Downloaded 389 times
Unfortunately I have the same problem.
Tried with 4.5 hrs of media (7 files) and tried with 21 mins of media (1 file), that is the log supplied.
Using both the latest beta and v1.3.0.0. The conversion works fine 100%, but the process does not complete and just sits there with the two buttons Cancel and Pause.
Burning the files separately works Ok.
Hello all,
Please can you explain what's happening after conversion?
The burn windows opens, but the burn process doesn't start?
Can you select your burner in the list? If yes, the burn button stay disabled?
If I understand, you can burn by using "burn an already converted project" function?
Thanks you!
Thanks you!
With the settings I was using after conversion no other windows opened.
The disk was not burned, so I would eventually cancel and the burn the files with CopyTo.
However, I've tried again with one file, but this time in the burn settings I unselected "Don't prompt before erasing a rewriteable media" prior to conversion.
This time the burn window appeared and I selected Yes for "Do you want to start the process", then the disk was burnt.
Nothing happens after the conversion at all.
The burn window does not open and the burn process does not start.
yes i can select the burner in the list.
no i can't select "burn already converted project"due to it being greyed out.
To burn the project i would have to use another different program to burn.
I have used this burner with your other program ConvertXtoDVD 5 and have no problems burning at all.
Cheers
Renits
Cheers
Renits
I am having this same issue with the newest version.
Please download and install the last beta version, with all 3 clean options checked in installer process.
Cedric, did exactly as you requested and still no burn at the end of the conversion process. It hangs on the screen. I have sent the logs and screen shot to tech support earlier. Please advise asap.
