WWW.INSTANTENCORE.COM
SUPERGAN
Post by SUPERGAN »
I use VSO Downloader to capture music files from www.instantencore.com.
I click on a music file and it shows in the downloader list. On some occasions it will download immediately other times it takes several attempts to get started. Very often it will download 90% of the file and stop. Sometimes it I repeat the download it will get all of the file successfully.
Anybody know what it happening?
This is a sample http://instantencore.com/music/player.a ... Id=5154636
AV LOADER: Opening file "D:\VSODOWNLOADER2\10589852422888.part"
If I use the live recording function it creates interference on the recording.
Re: WWW.INSTANTENCORE.COM
No problems at all detecting and downloading. Mp3 file is intact and plays fine after download.
SUPERGAN
Post by SUPERGAN »
Very Interesting, thank you for trying.
It's quite strange in that it looks like a timing issue in that it says for example 30 secs to run and after 90 the transfer rate will slow dramatically and then stop . I have 2 different isps and is the same on both. Other sites I regularly with vso and they are fine. If I try the download again sometimes it will work but sometimes not.
I will persevere.
Benjamin
Post by Benjamin »
no problem on my side with version 4.2.0.9
