Using Secure Stream
rwmol
Using Secure Stream
Post by rwmol »
In order to download music from a web site I have to use Secure Stream. The file will download but after 1 or 2 seconds after the download starts a small portion of the beginning of the tune is missing. This behavior happens on every download.
An example is attached.
Blue Bossa Rhythm.mp3
(3.47 MiB) Downloaded 1885 times
Re: Using Secure Stream
Where do you download from?
rwmol
Post by rwmol »
Grooveshark.com
Benjamin
Post by Benjamin »
rwmol
Post by rwmol »
[quote="Benjamin"]Did you try:
http://html5.grooveshark.com[/quote]
No I didn't. Didn't know it existed. Thanks. Issue solved.
rwmol
Post by rwmol »
Well. Now everything is blocked on Grooveshark. VSO downloader doesn't work on either web address.
Benjamin
Post by Benjamin »
this issue has been solved in the latest version
