Latest beta version - 3.5.0.0
Latest beta version (3.5.0.0) :
Blu-ray Converter Ultimate:
(no beta see official version)
DVD Converter Ultimate
Latest official (stable) versions are 3.5.0.0:
http://www.vso-software.fr/download.php
Blu-ray & DVD Converters - 3.5.0.0
- 0008534: [Bug] Open file dialog filter doens't work in video editor (cedric) - resolved.
- 0008532: [Suggestion] Add an option to abort conversion on first encoding error (cedric) - resolved.
- 0008531: [Bug] DVD menus rendered in 4/3 when DVD PAL 16/9 or NTSC 16/9 profiles are selected (cedric) - resolved.
- 0008526: [Bug] letterbox always saved in advanced editor even when custom values entered (cedric) - resolved.
- 0008525: [Bug] mkv remux + 2 pass conversion doesnt finish (cedric) - resolved.
- 0008524: [Bug] conversion error when adding subtitles to Ipad conversion (cedric) - resolved.
- 0008523: [Bug] settings not applied to dvd output (cedric) - resolved.
- 0008522: [Bug] Bad aspect ratio in thumbnail when converting (cedric) - resolved.
- 0008521: [Bug] ipad h264 conversion much slower than previous versions (cedric) - resolved.
- 0008520: [Bug] cant check cuda in settings (cedric) - resolved.
Blu-ray & DVD Converters - 3.4.0.22
- 0008493: [Suggestion] Take input video SAR into account to display static preview (Video editor) (cedric) - resolved.
- 0008490: [Crash] Getting error when starting conversion with custom profile selected (cedric) - resolved.
Blu-ray & DVD Converters - 3.4.0.21
- 0008486: [Bug] DTS/TrueHD/AC3 7.1 audio tracks are not remuxed even if requested by user (problem with Blu-ray output only) (cedric) - resolved.
- 0008485: [Bug] Getting error when Max.bitrate value is empty (custom profile editor) (cedric) - resolved.
- 0008484: [Bug] Add VCD output formats in main profiles (cedric) - resolved.
Thank you for your help!
vsotrialuser
Re: Latest beta version - 3.4.0.8
Post by vsotrialuser »
Hi all,
While evaluating the Blu-Ray Converter with the german Disney Blu-Ray "Planes", I'm having the following problems:
1) Planes won't work with the current stable version 3.3. That version crashes.
2) Found the latest beta in this forum. That version does not crash, however, it does NOT correctly rip the english subtitles (They are shown in the preview, but are missing in the converted DVD folder (limited to the first 10 minutes due to the trial limitations)). Here's the log.
HTH,
Chris
Code: Select all
:std_log='C:\ProgramData\VSO\Blu-ray Converter Ultimate\3\Log\Blu-ray Converter Ultimate 3_mainlog_.20140729.211819.349.log'
:library=false
:app_name=BlurayConverterUltimate.exe
:app_version=3.4.0.8
:most_recent=first
:event_header='{time}  {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
21:18:19.329  ------------    ***********BlurayConverterUltimate.exe:4604 Log session stop after 7 minute(s) 26 second(s) 86 millisecond(s)***********
21:15:53.059  Info            Total converted files size: 338 Mb.
21:09:28.500  Info                    [ ] Loop playback
21:09:28.499  Info                    [x] Play titles one after the other
21:09:28.497  Info                    [ ] Return to title menu after titleset playback
21:09:28.496  Info                    [x] Skip root menu initially
21:09:28.495  Info                    [x] Auto-start playback
21:09:28.494  Info                    No menu generated
21:09:28.494  Group               Video DVD menu options
21:09:28.493  Info                    Output target size : DVD-5 (4300 MB)
21:09:28.493  Info                    Number of core(s) used for encoding : 4
21:09:28.492  Info                    Number of core(s) used for decoding : 4
21:09:28.491  Info                    [ ] Use 2 pass encoding
21:09:28.490  Info                    [ ] Use best video quality settings
21:09:28.489  Info                    [ ] Use hardware decoding (if possible)
21:09:28.488  Info                    Max simultaneous conversions: 4
21:09:28.488  Group               Advanced encoding options
21:15:52.873  ------------            ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
21:15:52.872  Info                    subtitle #9 - Encoded subtitles frames: 0
21:15:52.870  Info                    subtitle #8 - Encoded subtitles frames: 158
21:15:52.869  Info                    subtitle #7 - Encoded subtitles frames: 171
21:15:52.867  Info                    subtitle #6 - Encoded subtitles frames: 3
21:15:52.866  Info                    subtitle #5 - Encoded subtitles frames: 4
21:15:52.864  Info                    DVD sectors written - video: 121399, audio: 49975, subtitle: 350
21:15:52.862  Info                    video #1 - Processed video frames: 14386 (17982 frames encoded, 0 frames dropped, 3596 frames duplicated)
21:09:28.579  ------------            +--> [subtitle #9 - dvd_subtitle subtitle, 720x480  [it]]
                                      +-[subtitle #8 - hdmv_pgs_subtitle subtitle]
                                      +--> [subtitle #8 - dvd_subtitle subtitle, 720x480  [de]]
                                      +-[subtitle #7 - hdmv_pgs_subtitle subtitle]
                                      +--> [subtitle #7 - dvd_subtitle subtitle, 720x480  [it]]
                                      +-[subtitle #6 - hdmv_pgs_subtitle subtitle]
                                      +--> [subtitle #6 - dvd_subtitle subtitle, 720x480  [en]]
                                      +-[subtitle #5 - hdmv_pgs_subtitle subtitle]
                                      +--> [subtitle #5 - dvd_subtitle subtitle, 720x480  [en]]
                                      +-[subtitle #4 - hdmv_pgs_subtitle subtitle]
                                      +--> [audio #4 - ac3 audio, 48000Hz, 6 Ch., 448 Kbps [de]]
                                      +-[audio [deu] dts main audio 5.1 Ch., 48000 Hz, 1536 Kbps]
                                      +--> [audio #3 - ac3 audio, 48000Hz, 6 Ch., 448 Kbps [it]]
                                      +-[audio [ita] dts main audio 5.1 Ch., 48000 Hz, 1536 Kbps]
                                      +--> [audio #2 - ac3 audio, 48000Hz, 6 Ch., 448 Kbps [en]]
                                      +-[audio [eng] dts main audio 5.1 Ch., 48000 Hz, 1536 Kbps]
                                      +--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29,97Fps, 4970 Kbps [un]]
                                      +-[video h264 1920x1080 16:9 yuv420p, 23,98 fps, 0 Kbps]
                                      Output file: C:\DVD\Planes - Blu-ray™\VIDEO_TS\VTS_01_1.VOB
                                      Input file: P:\VIDEO\BLU-RAY\PLANES\BDMV\INDEX.BDMV
                                      Video filters used:
                                      - DeInterlace filter: FFmpeg
                                      - Scale filter: linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
21:09:28.576  Info                    Chapters to generate: 30
21:09:28.486  Info                    Added in conversion queue list...
21:09:28.432  Group               ******************** Titleset #1 - ~91 min. File: "Planes - Blu-ray™" -> VTS_01_1.VOB - DVD NTSC Video structure ********************|GK_TITLESET|
21:09:28.431  Info                Encoding options: Medium Project (Automatic)
21:09:28.431  Info                Target size: 4,20 Gb.
21:09:28.177  Group           Conversion to "DVD Video NTSC 16/9" started at 21:09:28: 1 sequence(s) to encode|GK_CONVERT_SESSION|
21:08:52.894  Info            Found features
                              ^^^Repeated 2 Times in 992 millisecond(s)^^^
21:08:52.743  Info            Build OK
21:08:51.876  Info            Source is OK
21:08:50.462  Info            Media loaded
21:08:28.510  Info            Total Physical Memory : 16381 Mb.
                              Available Physical Memory : 14043 Mb.
                              Memory Load  : 14%
                              Available Virtual Memory : 3856 Mb.
                              Total Memory : 17403 Mb.
                              Available Memory : 14921 Mb.
21:08:28.509  Info            Processor AMD Athlon(tm) II X4 640 Processor with 4 core(s) CPU
                              Supported instruction set: MMX,ExMMX,3DNow!,Ex3DNow,sse,sse2 (slow),sse3,sse4A
21:08:28.501  Info            OS : Windows 7 (64 bits), Build 7601, service pack 1.0
                              file name : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\3\BlurayConverterUltimate.exe
                              file version : 3.4.0.8
                              User language   : German (Germany)
                              System language : German (Germany)
21:08:27.048  Group           Burn engine events
21:08:27.009  ------------    *********************BlurayConverterUltimate.exe:4604 Log session start 2014-07-29 at 21:08:26.973**********************
Sorry about this issue, I've sent you an internal version, can you report back on how it works for you?
vsotrialuser
Hi Claire,
thanks. That version has the same problem, sorry.
HTH,Chris
Code: Select all
:crash_log='C:\ProgramData\VSO\VSO Video Converter\1\Log\VSO Video Converter 1_crashlog_.20140731.125444.790.log'
:library=false
:app_version=1.4.0.10
:most_recent=first
:status=started
:group_indent=4
13:09:43.182  Info                No disc in drive.
13:09:41.124  Info                Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
13:09:41.123  Info                Drive has Serial ATA physical interface
13:09:41.122  Info                New Drive selected : 0 - HL-DT-ST BD-RE  BH10LS30 1.02 [H:]
12:54:44.829  Group           Burn engine events
12:54:44.791  ------------    ************************vsoVideoConverter.exe:4872 Log session start 2014-07-31 at 12:54:44.756*************************
k Mirror with video in top 1/3 of screen in root menu, contains 4 page(s)
12:56:45.077  Group               Video DVD menu options
12:56:45.076  Info                    Output target size : DVD-5 (4300 MB)
12:56:45.075  Info                    Number of core(s) used for encoding : 4
12:56:45.075  Info                    Number of core(s) used for decoding : 4
12:56:45.074  Info                    [ ] Use 2 pass encoding
12:56:45.073  Info                    [ ] Use best video quality settings
12:56:45.072  Info                    [ ] Use hardware decoding (if possible)
12:56:45.071  Info                    Max simultaneous conversions: 4
12:56:45.071  Group               Advanced encoding options
13:09:40.421  ------------            ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
13:09:19.609  Info                    Menu built successfully
                                      ^^^Repeated 3 Times in 20 second(s) 807 millisecond(s)^^^
13:06:49.587  Error                   [decoder][h264]: Missing reference picture, default is 65562
13:06:49.584  Error                   [decoder][h264]: reference picture missing during reorder
13:06:49.573  Error                   [decoder][h264]: Missing reference picture, default is 65562
13:06:49.570  Error                   [decoder][h264]: reference picture missing during reorder
13:06:49.557  Error                   [decoder][h264]: Missing reference picture, default is 65562
13:06:49.554  Error                   [decoder][h264]: reference picture missing during reorder
13:06:49.542  Error                   [decoder][h264]: Missing reference picture, default is 65562
13:06:49.539  Error                   [decoder][h264]: reference picture missing during reorder
13:06:45.729  Error                   [decoder][h264]: Missing reference picture, default is 65706
13:06:45.726  Error                   [decoder][h264]: reference picture missing during reorder
13:06:45.714  Error                   [decoder][h264]: Missing reference picture, default is 65706
13:06:45.711  Error                   [decoder][h264]: reference picture missing during reorder
13:06:45.701  Error                   [decoder][h264]: Missing reference picture, default is 65706
13:06:45.698  Error                   [decoder][h264]: reference picture missing during reorder
13:06:45.690  Error                   [decoder][h264]: Missing reference picture, default is 65706
13:06:45.687  Error                   [decoder][h264]: reference picture missing during reorder
13:06:45.210  Info                    Menu built successfully
13:04:33.736  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:33.733  Error                   [decoder][h264]: reference picture missing during reorder
13:04:33.717  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:33.714  Error                   [decoder][h264]: reference picture missing during reorder
13:04:33.700  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:33.697  Error                   [decoder][h264]: reference picture missing during reorder
13:04:33.686  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:33.684  Error                   [decoder][h264]: reference picture missing during reorder
13:04:32.471  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:04:32.469  Error                   [decoder][h264]: reference picture missing during reorder
13:04:32.455  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:04:32.453  Error                   [decoder][h264]: reference picture missing during reorder
13:04:32.440  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:04:32.437  Error                   [decoder][h264]: reference picture missing during reorder
13:04:32.426  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:04:32.424  Error                   [decoder][h264]: reference picture missing during reorder
13:04:31.255  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:31.253  Error                   [decoder][h264]: reference picture missing during reorder
13:04:31.239  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:31.238  Error                   [decoder][h264]: reference picture missing during reorder
13:04:31.220  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:31.218  Error                   [decoder][h264]: reference picture missing during reorder
13:04:31.209  Error                   [decoder][h264]: Missing reference picture, default is 65586
13:04:31.207  Error                   [decoder][h264]: reference picture missing during reorder
13:04:29.505  Info                    Menu built successfully
13:03:55.446  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:03:55.444  Error                   [decoder][h264]: reference picture missing during reorder
13:03:55.434  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:03:55.432  Error                   [decoder][h264]: reference picture missing during reorder
13:03:55.421  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:03:55.420  Error                   [decoder][h264]: reference picture missing during reorder
13:03:55.410  Error                   [decoder][h264]: Missing reference picture, default is 65682
13:03:55.409  Error                   [decoder][h264]: reference picture missing during reorder
13:03:53.735  Info                    Menu built successfully
13:03:37.148  Info                    Building ROOTCHAPTERS & SETTINGS menus using template: Black Mirror with video in top 1/3 of screen in root menu
13:03:37.133  Info                    subtitle #6 - Encoded subtitles frames: 158
13:03:37.132  Info                    subtitle #5 - Encoded subtitles frames: 3
13:03:37.131  Info                    subtitle #4 - Encoded subtitles frames: 4
13:03:37.130  Info                    DVD sectors written - video: 121718, audio: 33318, subtitle: 171
13:03:37.128  Info                    video #1 - Processed video frames: 14386 (17982 frames encoded, 0 frames dropped, 3596 frames duplicated)
12:56:45.157  ------------            +--> [subtitle #6 - dvd_subtitle subtitle, 720x480  [de]]
                                      +--> [subtitle #4 - dvd_subtitle subtitle, 720x480  [en]]
                                      +--> [audio #3 - ac3 audio, 48000Hz, 6 Ch., 448 Kbps [de]]
                                      +--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29,97Fps, 5360 Kbps [un]]
                                      Output file: C:\DVD\Planes - Blu-ray™ - Main feature (default) angle\VIDEO_TS\VTS_01_1.VOB
                                      Video filters used:
12:56:45.155  Info                    Chapters to generate: 21
12:56:45.069  Info                    Added in conversion queue list...
12:56:45.063  Info                    Menu fit: Text size reduced from 36.00 to 33.00 in style "title"
12:56:44.802  Group               ******************** Titleset #1 - ~91 min. File: "Planes - Blu-ray™ - Main feature (default) angle" -> VTS_01_1.VOB - DVD NTSC Video structure ********************|GK_TITLESET|
12:56:44.802  Info                Encoding options: Medium Project (Automatic)
12:56:44.801  Info                Target size: 4,20 Gb.
12:56:44.287  Group           Conversion to "DVD Video NTSC 16/9" started at 12:56:45: 1 sequence(s) to encode|GK_CONVERT_SESSION|
12:55:01.737  Info            Found features
                              ^^^Repeated 2 Times in 749 millisecond(s)^^^
12:55:01.608  Info            Build OK
12:55:01.029  Info            Source is OK
12:55:00.632  Info            Media loaded
12:54:46.255  Info            Total Physical Memory : 16381 Mb.
                              Available Physical Memory : 14021 Mb.
                              Memory Load  : 14%
                              Available Virtual Memory : 3864 Mb.
                              Available Memory : 14882 Mb.
12:54:46.254  Info            Processor AMD Athlon(tm) II X4 640 Processor with 4 core(s) CPU
12:54:46.246  Info            OS : Windows 7 (64 bits), Build 7601, service pack 1.0
                              file name : C:\Program Files (x86)\VSO\VSO Video Converter\1\vsoVideoConverter.exe
                              file version : 1.4.0.10
actually I didn't ask, have you tried selecting the subtitles? DVD subtitles need to be activated. If you use a player on a computer this is often in the right click or available in the menu (menu of the movie - created by our software)
vsotrialuser
Yes, I did. The preview displays them, but the DVD folder does not have them. The german subtitles are there, but not the english. The background of the german subtitles is black, not transparent, contrary to the settings.
You can see in the log that the program has a problem with the english subtitles (english 3 or 4 frames, german 158 frames):
HTH,Chris
Thanks for your testing and I am sorry about this problem. I unfortunately will not have a fix for about two weeks. I opened an official bug report for this issue
http://bugs.vso-software.fr/view.php?id=8279
(you can create an account to follow up on the issue, know that this thread will be updated however when a version is released that fixes the issue).
vsotrialuser
Claire wrote:Thanks for your testing and I am sorry about this problem. I unfortunately will not have a fix for about two weeks.
Thanks. Will check back in regular intervals.
Best,
Chris
vsotrialuser
Addendum: Subtitles are rendered correctly in the preview,
Subtitles in the preview
but not in the DVD folder.
Subtitles as they appear in the DVD folder
The DVD subtitles have a black background, the background in the preview is transparent (which I prefer).
Also: Forum functionality (quote/code/attachment etc.) is broken.
mod edit: No, you just had setting to "Disable BBCode".
ok thanks for this additionnel information and your images!
vsotrialuser
vsotrialuser wrote:mod edit: No, you just had setting to "Disable BBCode".
So it is, thanks!
Didn't know such a setting existed, nor that it would be disabled by default.
Re: Latest beta version - 3.4.0.12
new beta version published and it should fix all the subtitle problems reported here
vsotrialuser
Claire wrote:new beta version published and it should fix all the subtitle problems reported here
Confirmed! English subtitles are now present and rendered correctly with transparent background.
Will continue to test this version and report back if I find other problems.
HTH, Chris
ok thanks so much for getting back to us!
alan1476
Re: Latest beta version - 3.4.0.13
Post by alan1476 »
Latest Bluray file 3.4.0.13 download is corrupted.
can you try again? I just downloaded and installed no problem.
Maybe Cedric corrected after seeing your message, I don't know, but now it seems to work
alan1476
Post by alan1476 »
Claire wrote:can you try again? I just downloaded and installed no problem.
Yup, its all fixed now, even the file size is different, I also reported it in the bug tracking system so someone fixed it, thank you, Claire.
ok thanks for confirming and your quick help!
Re: Latest beta version - 3.5.0.0
new official version posted 3.5.0.0
