Latest beta version - 1.5.0.0
Latest beta version (1.5.0.0 ) :
does not exist see latest official version
(currently no beta version)
Latest official (stable) version is 1.5.0.0:
http://www.vso-software.fr/products/vid ... verter.php
Video Converter - 1.5.0.0
- 0008533: [Bug] Open file dialog filter doens't work in video editor (cedric) - resolved.
- 0008530: [Suggestion] Add an option to abort conversion on first encoding error (cedric) - resolved.
- 0008529: [Bug] DVD menus rendered in 4/3 when DVD PAL 16/9 or NTSC 16/9 profiles are selected (cedric) - resolved.
- 0008512: [Bug] cant check cuda in settings (cedric) - resolved.
- 0008509: [Bug] ipad h264 conversion much slower than previous versions (cedric) - resolved.
- 0008517: [Bug] Bad aspect ratio in thumbnail when converting (cedric) - resolved.
- 0008507: [Bug] settings not applied to dvd output (cedric) - resolved.
- 0008494: [Crash] conversion error when adding subtitles to Ipad conversion (cedric) - resolved.
- 0008505: [Bug] mkv remux + 2 pass conversion doesnt finish (cedric) - resolved.
- 0008506: [Bug] letterbox always saved in advanced editor even when custom values entered (cedric) - resolved.
Video Converter - 1.4.0.22
- 0008492: [Suggestion] Take input video SAR into account to display static preview (Video editor) (cedric) - resolved.
- 0008491: [Feature Request] Keep history (MRU list) of loaded projects (cedric) - resolved.
- 0008489: [Crash] Getting error when starting conversion with custom profile selected (cedric) - resolved.
Video Converter - 1.4.0.21 (Released 2014-09-11) [ View Issues ]
- 0008488: [Suggestion] Associate .vcprj files to Video Converter (project files) (cedric) - resolved.
- 0008487: [Suggestion] Remember encoder output profile in projects (cedric) - resolved.
- 0008481: [Suggestion] Add VCD output formats in main profiles (cedric) - resolved.
- 0008480: [Bug] Getting error when Max.bitrate value is empty (custom profile editor) (cedric) - resolved.
- 0008479: [Bug] DTS/TrueHD/AC3 7.1 audio tracks are not remuxed even if requested by user (problem with Blu-ray output only) (cedric) - resolved.
Thank you for your help!
Re: Latest beta version - 1.4.0.8
New nVidia drivers released v340.52 WHQL. nVidia Hardware Decoding still doesn't work.
Also, is the Trial version the same as the FREE version ? My friend wanted to try this program and I noticed that there is a Free version. I installed it on her computer and it comes up saying it's a Trial ? It doesn't say anywhere that it's the Free version.
There is no "free" version, there is a free trial, but that only converts the first 10 minutes of a file.
Why do you think hardware decoding is not working?
On your website there is a 'VSO Free MKV WebM Converter'. How do you not know this ?
Since nVidia released their last Beta and WHQL drivers the 'nVidia Hardware Decoding' option is greyed out. I told Cedric about this when nVidia released new Beta drivers but he said he'll take a look on the next WHQL drivers (which came out about 2 days ago).
You are right, I did forget about it, I am sorry, converting to Mkv, Webm, audio ogg profiles should work with no limitation, if there is one then there is a bug, this was a bug for example for profile MKV-VP8 in version 3.3.0.0 fixed in versions superior to thatcribber wrote:On your website there is a 'VSO Free MKV WebM Converter'. How do you not know this ?
Ok I will see with Cedric, but I will not have an answer until near the end of august.cribber wrote: Since nVidia released their last Beta and WHQL drivers the 'nVidia Hardware Decoding' option is greyed out. I told Cedric about this when nVidia released new Beta drivers but he said he'll take a look on the next WHQL drivers (which came out about 2 days ago).
So the Free version is actually the same download as the Trial version but converting to MKV is unrestricted ?? If not then when doesn't it say it's the Free version when installed ?You are right, I did forget about it, I am sorry, converting to Mkv, Webm, audio ogg profiles should work with no limitation, if there is one then there is a bug, this was a bug for example for profile MKV-VP8 in version 3.3.0.0 fixed in versions superior to that
A whole month ? Why is it going to take a month ? I guess i'll have to stay on outdated drivers then.Claire wrote:Ok I will see with Cedric, but I will not have an answer until near the end of august.
Edit: Why aren't the quotes working properly ?
for the quotes you have to uncheck the bbcode option
(with admin power, I edit your post and uncheck the option in forums posts I see this problem, like yours, that is why it is now different)
So the Free version is actually the same download as the Trial version but converting to MKV is unrestricted ?? If not then why doesn't it say it's the Free version when installed ?claire wrote:You are right, I did forget about it, I am sorry, converting to Mkv, Webm, audio ogg profiles should work with no limitation, if there is one then there is a bug, this was a bug for example for profile MKV-VP8 in version 3.3.0.0 fixed in versions superior to that
cribber wrote:Since nVidia released their last Beta and WHQL drivers the 'nVidia Hardware Decoding' option is greyed out. I told Cedric about this when nVidia released new Beta drivers but he said he'll take a look on the next WHQL drivers (which came out about 2 days ago).
A whole month ? Why is it going to take a month ?Claire wrote:Ok I will see with Cedric, but I will not have an answer until near the end of august.
Just out of interest, why aren't you replying to my questions ? Has Cedric gone AWOL ?cribber wrote:So the Free version is actually the same download as the Trial version but converting to MKV is unrestricted ?? If not then why doesn't it say it's the Free version when installed ?claire wrote:You are right, I did forget about it, I am sorry, converting to Mkv, Webm, audio ogg profiles should work with no limitation, if there is one then there is a bug, this was a bug for example for profile MKV-VP8 in version 3.3.0.0 fixed in versions superior to that
cribber wrote:Since nVidia released their last Beta and WHQL drivers the 'nVidia Hardware Decoding' option is greyed out. I told Cedric about this when nVidia released new Beta drivers but he said he'll take a look on the next WHQL drivers (which came out about 2 days ago).A whole month ? Why is it going to take a month ?Claire wrote:Ok I will see with Cedric, but I will not have an answer until near the end of august.
That is correct. When you press convert when a profile is selected that is not free- a pop up will appear informing the user which profiles can be used without limitation.cribber wrote:So the Free version is actually the same download as the Trial version but converting to MKV is unrestricted ??
People take vacation or can be busy doing other things too.cribber wrote:A whole month ? Why is it going to take a month ?
Latest version - 1.3.0.0
how does it work with menus,
just 4 episode do drop, and DVD 5 PAL and prepare menus that matter what I set in settings.
Re: Latest version - 1.3.0.0
I really do not understand. Are you having a problem? If so, please say what it is and also post your log file from the conversion.firewalkernl wrote:how does it work with menus,
hello,
I have a problem,
all the time, through this program.
it is not possible, exchange to convertxtodvd.
VSO I have absolutely nothing.
subtitles, is not good and sound.
I'm done with that VSO video converter.
each time new version's only problem.
:roll: :roll: :roll: :roll: :roll:
I have a problem,
I think you should contact VSO Support directly and summarize your problem
http://www.vso-software.fr/contactform.php
State also what you would like: solution, exchange license, refund....
ok.
Claire wrote:Hello,
Hi Guys
Converting a FLV file To MP4 H264 using the inbuilt Generic Video setting if you go to the Advanced Edit options bit rate shows at very low 360 if I use V1.3xx it displays a higher bit rate in addition, playback of the converted MP4 file stutters during playback if I use the file converted using V1.4.0.8 but if I use V1.3.XX the latest stable for the conversion the Mp4 converted file now will playback without stutter.
In addition, the FPS during conversion with V1.4.0.8 is only giving 227 with Cuda option but getting 557 using V1.3.xx with same selected generic video MP4 H264 setting.
I am getting the same problem with stutter of a converted AVI Xvid file with V1.4.0.8. The FLV file used for conversion playbacks stutter free (tried a few players with V1.4.0.8 conversions all stuttered even VSO's media player).
Have gone back to V.1.3xx for now I believe this this problem only happened with V1.4.0.8
Budda [sic]
From Down Under
My All-rounder Rig
CPU: I7-2600K @ 4.6 GHZ
RAM: Corsair 16 Gig DDR3 1866
HDD: 11TB
Network & BU Thecus N5550
From Down Under
My All-rounder Rig
HDD: 11TB
Re: Latest beta version - 1.4.0.12
new beta published
Re: Latest beta version - 1.4.0.13
new beta published again
Re: Latest beta version - 1.4.0.15
v1.4.0.14
Reference Frames and B-Frames don't save in the custom settings.
No desktop icon.
Possibly other stuff.
v1.4.0.15
Video Aspect Ratio in custom settings doesn't work (greyed out).
Please add 'Intel QuickSync' for GPU acceleration. Thanks.
No desktop icon.
v1.4.0.15
The custom profiles do not store the H264 options for Preset and Tune. It would be good to have an explanation or guide to some of the new options in the custom profile.
No remux of full DTS audio (HD or HD MA).
