Protocol not yet supported (DL_RTMP)
KuroTenshi28
Post by KuroTenshi28 »
Hello !
I am using VSO Downloader Ultimate (4.0.0.19) to download videos from a manga streaming website (animedigitalnetwork.fr) in which I am a Premium Member (9€99 a month). I find it a shame to pay for not being able to download (like in Wakanim.tv). It's for personal use, because of my low bandwidth.
It doesn't work and I have this message (in the log) : Protocol not yet supported (DL_RTMP).
Will this protocol be supported in next versions ?
Thank you for your answer.
KuroTenshi28
Here is the complete log file :
[quote]:std_log='C:\ProgramData\VSO\VSO Downloader\4\log\downloader_log.20140711.212953.277.log'
:library=false
:app_name=VsoDownloader.exe
:app_version=4.0.0.19
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
21:30:51.793 Warning Protocol not yet supported (DL_RTMP)
21:30:51.743 Group rtmp
21:30:51.743 Group conversion
21:30:51.743 Group referrer title
21:30:51.743 Group temporary
21:30:51.743 Group original
21:30:51.776 Debug File name changed: <unknown_file_name> replaced by <unknown>
21:30:51.767 Debug Extension changed: <ext> replaced by <flv>
21:30:51.743 Group download
21:30:51.743 Group renamer
21:30:51.742 Group item_63540797451623
21:29:52.305 Group downloads
21:29:54.177 Info Streaming monitoring enabled: Realtek PCIe GBE Family Controller
21:29:54.177 Info selected driver: VSO EVE (NDIS)
21:29:52.305 Group online NIC
21:29:54.119 Important Carte réseau détectée automatiquement: Realtek PCIe GBE Family Controller
21:29:54.119 ------------ ************************************Detection of the online network adapter finished************************************
21:29:53.373 Info Available network adapters: 1
21:29:54.117 Important ONLINE
21:29:54.117 Debug HTTP pkts -> GET=4 | HTTP=4
21:29:54.116 Debug raw pkts -> incoming=50 | outgoing=36
21:29:53.373 Info MAC address: 00:1A:4D:47:C1:B2
21:29:53.373 Info Description: Realtek PCIe GBE Family Controller
21:29:53.373 Info Name: \DEVICE\{7EE893B3-AFF9-4E78-8B77-4AD6E76D5743}
21:29:53.373 Group NIC_0
21:29:53.372 ------------ ************************************Starting detection of the online network adapter************************************
21:29:53.372 Group VSO EVE (NDIS)
21:29:53.371 Info VSO EVE (NDIS) 0.2 driver is installed: started
21:29:53.359 Info WinPcap (libpcap) 4.1.0.2001 driver is installed: started
21:29:52.129 Group NIC manager
21:29:53.354 Info Settings applied
21:29:52.305 Info Ad Blocker successfully loaded
21:29:52.156 Info Network adapters successfully loaded
21:29:52.154 Info Secure stream successfully loaded
21:29:52.153 Info Mimes successfully loaded
21:29:52.136 Info Ports to monitor successfully loaded
21:29:52.133 Info Registry successfully loaded
21:29:52.130 Info Output folder path: C:\Users\Sylvain\Documents\VSO Downloader\
21:29:52.129 Group settings
21:30:51.742 Info Media detected:
21:29:52.305 Group pkt manager
21:29:52.305 Group Lumberjack
21:29:52.305 Group HLS
21:29:52.305 Group HDS
21:29:52.129 Group detection
21:29:53.287 Info Winsock: Version 2.2 - WinSock 2.0 Running
21:29:53.286 Info avutil.dll: 52.34.100.331
21:29:53.286 Info avformat.dll: 55.7.100.331
21:29:53.286 Info avcodec.dll: 55.12.100.331
21:29:53.285 Info ad_c.dll loaded: version 1.4
21:29:53.285 Info wpcap.dll successfully loaded: WinPcap version 4.1.2 (packet.dll version 4.1.0.2001), based on libpcap version 1.0 branch 1_0_rel0b (20091008)
21:29:53.284 Info packet.dll successfully loaded: 4.1.0.2001 (driver)
21:29:52.128 Group external
21:29:52.128 Info Total Physical Memory : 4094 Mb.
Available Physical Memory : 833 Mb.
Memory Load : 79%
Available Virtual Memory : 1836 Mb.
Total Memory : 10233 Mb.
Available Memory : 6208 Mb.
21:29:52.128 Info Processor Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz with 4 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3 (slow),sse41
21:29:52.127 Info OS : Windows 7 (64 bits), Build 7601, service pack 1.0
file name : C:\Program Files (x86)\VSO\VSO Downloader\4\VsoDownloader.exe
file version : 4.0.0.19
User language : Français (France)
System language : Français (France)
21:29:52.127 ------------ **************************VsoDownloader.exe:3764 Log session start 2014-07-11 at 21:29:52.034***************************[/quote]
LouisM
Re: Protocol not yet supported (DL_RTMP)
Post by LouisM »
le protocole utilisé par animedigitalnetwork.fr est un type de RTMP. Le RTMP basique est compatible avec le Downloader, mais il existe d'autres types de RTMP un peu plus difficiles à récupérer, comme celui sur lequel tu sembles être tombé. On y travaille, mais on n'est pas en mesure de dire quand on le prendra en charge.
En attendant, tu peux peut-être trouver une solution ici :
http://forums.vso-software.fr/vso-downl ... 18077.html
Any question about VSO Downloader? See the FAQ.
KuroTenshi28
Coucou,
Merci pour votre réponse. L'essentiel est que ça avance. Je ne suis pas pressé. J'avais déjà utilise VSO Downloader pour du RTMP simple sous Youtube et ça fonctionnait. Donc je ne me fais pas de soucis. J'attendrai.
J'avais déjà opté en attendant pour la capture d'écran, mais ce n'est pas pratique, vu que la vidéo lague à cause du manque de bande passante. En plus il faut un très gros disque dur.
