what do you think about an additional select-option:
output folder: same as input folder
I'd rellay appreciate to see this in a future release^^.
Feature Request: Output folder == Source folder
Re: Feature Request: Output folder == Source folder
I entered your feature request here
http://bugs.vso-software.fr/view.php?id=8254
(you can create an account - it is a different database than the forum, if you want to follow-up on the issue, but if added it will be reported back here in this thread)
I don't know if it will be added or when.
Many thanks.
