Video Resize Method is NOT working properly
mue.mat
Post by mue.mat »
Hello again
2 more problems have ocurred while video converting:
1. Even when I put in "Settings" --> "Video Processing" --> "Video Resize Method" as default "Letterbox", this choice doesn't appear in the "Preview" box (down right) loading a movie file.
It appears "Automatic" ("Output" --> "Video Fit Method").
2. So I change "Output" --> "Video Fit Method" again to "Letterbox", but ConvertXtoHD doesn't convert to "Letterbox" because edges of the movie are "cut" ("Automatic" mode does cut, I tried out), and "Letterbox"-mode shoudn't cut at all.
Attached you find the log file.
Thanks for your help and kind regards
Matthias
ConvertXtoHD 1_mainlog_.20140803.134406.801.log
(6.56 KiB) Downloaded 388 times
Re: Video Resize Method is NOT working properly
New beta version (1.0.0.4) is out :
http://forums.vso-software.fr/post90087.html#p90087
Thank you for your feedback.
