weird audio
vsonut
weird audio
Post by vsonut »
OK...
2 movies of the .mpg format (mpg 4 that is).
2 computers (Windows 7 and Windows XP)
I get a weird audio distortion when converting to .3gp format.
I tried the default one (large), and custom.
I attached a zip file with a portion of the audio from the converted and non converted file.
Also in the attached zip file is the ... "log file" from my trying to convert this last time.
It can't be OS related because of 2 different versions of windows.
The only relation is both are AMD dual core (Laptop=Win7 , PC=WinXP).
When listening to the files, you will be able to see what I mean (esp when getting to talking spots).
PLEASE, does anyone have an answer !!
Fools Gold.zip
(9.9 MiB) Downloaded 491 times
vsonut
Re: weird audio
Post by vsonut »
Downloaded and tried the "beta" version, and it did not help at all.
Just in case its needed, here is some info on the file I was/am trying to convert.
( Info from Properties/Details for file in Windows 7)
Name. Fools Gold.mpg
Width- 720
Height- 960
Data Rate- 8000kbps
Total bitrate- 8224kbps
Frame rate- 29 frames/second
.... Audio
Bit rate- 224kbps
Channels- 2 (stereo)
Sample rate- 48 kHz
(Info from GSpot for movie)
Container - MPEG-2 Program Stream
Audio- MPEG-1 Layer 2
Soo ... why the audio distortion when converting it with VSO Video Conveter 1 with these settings ..
Container- 3GP
Video codec - MPEG-4
resoulution - 480x320 ...... FrameRate - (same as souce)
Aspect Ratio - (Fit on Destination)
Audio codec - AAC ....... Audio Channel (same as source)
Sample Rate- (same as source) ....... Beitrate per channel (same as source)
Subtite codec - (Embed in Video)
vsonut
Re: weird audio
Post by vsonut »
Do you guy's need any more info, in order to help ?
If so, what info, and how do I grab that info.
MyMojo
Re: weird audio
Post by MyMojo »
Hello! Have you tried using another program to see if you get better results? If no, try a free program off the web and see what happens. Always good for comparing results.
Copnm
Re: weird audio
Post by Copnm »
Hello vsonut,
I would recommend downloading "MediaInfo", exporting the file's info, and uploading it here for a start. As well as you should post your log of your most recent conversion.
Thanks for reading,
Neil M
MyMojo
Re: weird audio
Post by MyMojo »
Hi Neil,
Thought about mentioning that, but judging from the file info he posted, I think these have already been through a converter of some kind, and a good bet the problem is the 'original' files. Might not be, but thought it a good idea to narrow it down with something else to compare and see if it does the same thing.
Cheers
Garrett
vsonut
Re: weird audio
Post by vsonut »
Ok .. Will do
vsonut
Re: weird audio
Post by vsonut »
Found a work-around, but it still needs fixed.
OK.. here is what happened.
1. Original file says audio is at ...... 224 Kbps .. for the Bit Rate.
2. Converted file says audio is at .... 10.4 Kbps .. for the Bit Rate.
3. Program set the audio bit rate to .... Use Original unless unable to do so.
.... Only thing I can figure is the program couldn't do the 224 Kbps, and for some ungodly reason
decided that the extremely low number of 10.4 Kbps was the only alternative.
..... This needs to be fixed to maybe gravitate to the NEXT lowest or highest from the list.
..... My workaround, was to BUMP the Bit Rate to 32000.
Works great, but without a FIX, you have to still convert the file and listen for the echo, then do the work-around, ORRRR.
Use a program to see a file's info ever single time before using the program (which is a pain for us lazy people).
Thanks to all who answered my thread and postings.
FoolsGold-Help.zip
(1.63 KiB) Downloaded 634 times
Re: weird audio
Please, post your log files and your custom profile.
Thank you.
vsonut
Re: weird audio
Post by vsonut »
Logfile is outdated (from time I started the thread till now, so not so helpful).
BUT.... the profile I made I attached. Hope it helps someone else.
It didn't like attaching an XML, so used 7zip to contain it.
WideAndroidFix.zip
(582 Bytes) Downloaded 445 times
thermalzombie
Re: weird audio
Post by thermalzombie »
Maybe you should try 64000 for the audio bitrate at least then you will have 128 bitrate at 2 channel stereo.
At 32000 you are only getting 64 bitrate at 2 channel stereo that is pretty low for tv or movie.
Re: weird audio
Do you want to see if you still have the problem in our latest beta version?
http://forums.vso-software.fr/convertxt ... r-f51.html
If so would you upload one of the original video files if you still have one? I can provide instructions.
