Main title & multiple versions - how to pick...
whodo22
Post by whodo22 »
I have a Blu-ray that has 10 versions of the movie on the disc. How do you know which version to pick? Selecting more than one makes the file too big to put on a 4.7gb blank disc. I've already selected the first version and the result was not a complete movie. Scenes bounced around and played multiple times. The story was not complete from start to finish.
Re: Main title & multiple versions - how to pick...
Just to update the post, I know you have been in contact directly with VSO to fix this problem which is happening for the movie Divergent.
Current status is Work in progress, problem maybe related to decryption, not yet related to the use of Blu-ray Converter.
decypher
Post by decypher »
Has there been any update on this? I had Enders Game about a week ago with this exact same issue. It is a real PITA to deal with.
decypher wrote:Has there been any update on this? I had Enders Game about a week ago with this exact same issue. It is a real PITA to deal with.
are these redbox rentals?
decypher
Post by decypher »
Mine are netflix
another user has this problem with Return of the Jedi
decypher
Post by decypher »
That should only be a language angle. Each angle is a different language. The first one is english.
