Feature Request: CRF (Constant Rate Factor)
cribber
Post by cribber »
As the title, can you please add Constant Rate Factor to the H264 encoding options (like DVDFab & Handbrake). I suggest referencing DVDFab as the speed and quality far exceeds your converter (at the moment). I just want yours to be equal or better as you have some options in yours that are unique to converters. Thanks.
Re: Feature Request: CRF (Constant Rate Factor)
Hi all,
Please, take a look on the last beta version (1.4.0.14) : http://forums.vso-software.fr/post90200.html#p90200
