New beta version v3.5.0.24
Latest beta version (3.5.0.24 ) :
DVD Converter : no beta see latest official below
Blu-ray Converter : no beta see latest official below
Latest official (stable) version is 3.5.0.10:
http://vso-software.fr/products/bluray- ... verter.php
http://vso-software.fr/products/dvd-con ... verter.php
Last changes:
Blu-ray & DVD Converters - 3.5.0.24 (Released 2015-02-06) [ View Issues ]
- 0008725: [Bug] DVD Conveter press f2 to change name and get AV (cedric) - resolved.
- 0008438: [Bug] blu-ray to blu-ray conversion with 2 pass stops at 50% and best video quality (cedric) - resolved.
- 0009257: [Bug] av when converting blu ray tears for fears to DVD ntsc (cedric) - resolved.
- 0009372: [Bug] error converting with custom profile (cedric) - resolved.
- 0009387: [Suggestion] Take in account "output folder generation method" when custom profile output folder is set (cedric) - resolved.
- 0009386: [Suggestion] custom profile missing "Custom profile name" and "custom path" in the overview. (cedric) - resolved.
- 0009385: [Suggestion] Names of settings in custom profile editor should be the same in all places used (cedric) - resolved.
- 0009384: [Feature Request] add option "open explorer" to "Output folder generation" setting (cedric) - resolved.
- 0009112: [Feature Request] Add an option to split loaded files by chapters (import one titleset by chapter) (cedric) - resolved.
- 0009369: [Bug] blu-ray output freezing on samsung player (felicia) - resolved.
[10 issues]
Thank you for your help!
Last changes:
[10 issues]
Re: New beta version v3.5.0.5
This version locked up also while trying to load the video parts of a Blu-ray of Transformers : Age of Extinction Any help would be great
"This version locked up also while trying to load the video parts of a Blu-ray of Transformers"
Please provide more details...
What is locked? When?
Re: New beta version v3.5.0.6
when it is scanning video the program just locks up and the it says not responding
Re: New beta version v3.5.0.9
we were able to reproduce the problem a fix is coming soon
Re: New beta version v3.5.0.10
fixed in the latest beta
http://forums.vso-software.fr/latest-beta-t18295.html
Re: New beta version v3.5.0.11
I've found a rather annoying bug in this latest version. I was doing a straight rip from a blu-ray disc and the converter estimated the size to be over 9 terabytes, which is more than a bit absurd. Normally I wouldn't care about the estimated size, but the converter will no longer let me convert if it thinks I don't have room. Please add an option to ignore the space warning, as my NAS has over 8 terabytes free and I have to rip every episode individually with this newest version just to get past the required space error.
What profile are you converting to?
With the latest versions (3.5.0.10 and 3.5.0.11beta) I'm getting significant worse output quality than before (3.4.0.22). Very blocky videos and progressively worse as the video plays. Tried my usual Nexus 10 profile and the new iPhone 6 plus profile with the same blocky results. Revert back to 3.4.0.22 and the problem went away for the same multiple bluray .iso that I was converting. Settings were inherited from 3.4.0.22 to the 3.5.0.xx.
Ray
Ray
Can you post a log file from either of those conversions? A log file from each version would be great!
Here are the two log files. Identical source of the movie "Blended" ripped iso. Settings were the same as far as I could remember except I tried the iPhone 6 plus profile in 3.5.0.11. The video converted by 3.5.0.11 has significant blockiness.
- Blu-ray Converter Ultimate 3_mainlog_.20141021.062915.658.log
- 3.4.0.22
- (3.58 KiB) Downloaded 662 times
- Blu-ray Converter Ultimate 3_mainlog_.20141020.213858.755.log
- 3.5.0.11
- (5.75 KiB) Downloaded 643 times
Thanks for posting these. I think I reproduced the problem. I opened a bug report. I will let you know when we release a version that may fix this issue. Thanks,
Re: New beta version v3.5.0.20
when I rip a DVD, I always get ENGLISH instead of GERMAN.
I'm just trying the 2nd time to rip the DVD "The Big Lebowski" with 3.5.0.20 (never tried it before with another version!)
http://www.amazon.de/Big-Lebowski-Jeff- ... g+lebowski
(although format is printed 1.85:1 on DVD and not 1.77:1 as on Amazon),
and select GERMAN ... but the final rip as
---- Output container informations ----
* Name: Mpeg2-TS
* File extension: ts
---- VIDEO track informations ----
If possible, video stream will be copied (remuxed).
Otherwise, it will be encoded using these settings:
* codec: mpeg2video
* framerate: Same as source (if compatible)
* width: Same as source (if compatible)
* height: Same as source (if compatible)
* aspect ratio: Same as source (if compatible)
---- AUDIO tracks informations ----
If possible, audio streams will be copied (remuxed).
Otherwise, they will be encoded using these settings:
* codec: ac3
* channel count: Same as source (if compatible)
* samplerate: Same as source (if compatible)Hz
---- SUBTITLE tracks informations ----
If possible, subtitle streams will be copied (remuxed).
* codec: dvd_subtitle
is always ENGLISH.
VSO Player 1.4.9.495 plays it correctly from the original DVD when I switch to GERMAN.
Finally here is the mediainfo from a .vob file
General
Complete name : D:\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 31mn 11s
Overall bit rate : 4 589 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Duration : 31mn 11s
Bit rate mode : Variable
Bit rate : 3 601 Kbps
Maximum bit rate : 9 780 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.347
Time code of first frame : 00:59:57:10
Time code source : Group of pictures header
Stream size : 804 MiB (78%)
Audio #1
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 31mn 11s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 99.9 MiB (10%)
Audio #2
ID : 189 (0xBD)-129 (0x81)
Format : AC-3
Duration : 31mn 11s
Bit rate : 448 Kbps
Bit depth : 16 bits
Text #1
ID : 189 (0xBD)-32 (0x20)
Format : RLE
Format/Info : Run-length encoding
Text #2
ID : 189 (0xBD)-33 (0x21)
Format : RLE
* Name: Mpeg2-TS
* codec: mpeg2video
* codec: ac3
is always ENGLISH.
General
Format : MPEG-PS
Duration : 31mn 11s
Video
Format : MPEG Video
Duration : 31mn 11s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Audio #1
Format : AC-3
Duration : 31mn 11s
Bit rate : 448 Kbps
Bit depth : 16 bits
Audio #2
Format : AC-3
Duration : 31mn 11s
Bit rate : 448 Kbps
Bit depth : 16 bits
Text #1
Format : RLE
Text #2
Format : RLE
I have it ... I think it's a bug!
Although I've selected "deu" (German) only (see screen shot) - all audio tracks have been copied (due the profile? see above!).
In VSO Player when I play the ripped file I can switch the audio track to German.
Shouldn't only "deu" (German) be filtered?
Here from the ripped file ... English + German audio tracks:
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 52mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 360 MiB (9%)
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 52mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Text
Menu ID : 1 (0x1)
Format : DVB Subtitle
Codec ID : 6
Language : English
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 52mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 52mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Text
Menu ID : 1 (0x1)
Codec ID : 6
Language : English
When I change to profile from
* codec: ac3
to
Audio streams will be encoded using these settings:
* codec: ac3
and also only select "deu" German only (as screen shot above), I only get GERMAN.
Finally this is a bug and must be fixed.
When "If possible, audio streams will be copied (remuxed)." is selected in a profile, then all languages will be copied and not only those (the one - German in my case) selected.
* codec: ac3
to
* codec: ac3
Hello dosibo51,
I tried to reproduce your problem without success...
I created a custom profile using:
- "DVD PAL" as File format
- VIDEO: Checked "Copy (remux) if possible...", selected MPEG-2 PAL Video as codec, "Same as source (if compatible)" for framerate
- AUDIO: Checked "Copy (remux) if possible...", selected AC3 (DVD compatible) as codec, "Same as source (if compatible)" for all fields
- SUBTITLE: Copy option not checked, Embed in video selected.
With this profile, I always get (only) the audio tracks I selected in main interface (tree view) in output.
Please can you post your custom profile (located here: C:\ProgramData\VSO\DVD Converter Ultimate\3\custom_profiles)?
Can you post the log file of this conversion?
I've retested it with the existing profile and also created a new profile ... and it works correctly. Also the .xml looks identical.
Believe me that I have no idea ... maybe it happens again sooner or later.
Sorry for the time - but I've ripped it 3 times before - not just for fun and looked what I've selected.
Thanks!
Thanks!
Hello dosibo51,
This is a good news!
I trust you about all your test results you posted before...
I think I maybe have the reason of this strange behaviour: I added some parameters fixes functions in custom profile editor...
So I think that your problem was fixed when you opened your custom profile editor THEN SAVED IT.
Thank you for posting your feedbacks here...
Re: New beta version v3.5.0.24
bump - FYI a new beta has been posted that fixes some of the things reported here in this thread.
