buy convertx
Glynis10
buy convertx
Post by Glynis10 »
Hi I want to buy the latest version of convertxtodvd but not sure which one and is it guaranteed to work and give me good results and do you get a free upgrade?
Re: buy convertx
It all depends on your need.
Do you need to convert and burn movies to DVD?
Add multiple video clips with menu to DVD?
If yes, then ConvertXtoDVD is right choise.
If you need to convert to other formats or devices then VideoConverter is your choise,
If you need to convert and burn to BluRay then ConvertXtoHD is the option - but then you need to wait a little bit as it is not completely ready yet.
First two are working for 99% of users without any problems, and for those few there usually is a solution.
Results are usually very good, but end result can never be better than original source. In some cases some settings need to be adjusted for best possible result.
All VSO products offer free minor updates and bigger upgrades at least for one year from purchase.
Glynis10
Re: buy convertx
Post by Glynis10 »
I'm about to buy this product but do not want to put my card details in until I know I have the right one please help
I want the lates convertxtodvd
I want to convert downloaded movies to dvd
Glynis10
Re: buy convertx
Post by Glynis10 »
:D :D :D :D :D :D :D :D :D :D Yippeee I just purchased this product CONVERTXTODVD now I need help to make sure I work it properly xxxxx
My quote of the day try then buy
MyMojo
Re: buy convertx
Post by MyMojo »
