I was just trying new version 1.0.0.6.
I converted a mkv-movie into BluRay; BluRay-Structure comes out without problems, but when trying to play the burnt BluRay-Disc in common BluRay-player, menu comes up but when starting the movie there only comes sound, but image "stands still".
I tried everything: with/without 2-pass-converting and with/without best video quality.
There must be a bug.
Thanks for your help
Matthias
Converted BluRay-Structure DOES NOT play in BluRay-Player
Re: Converted BluRay-Structure DOES NOT play in BluRay-Playe
How does it play on your computer with VMP (our free media player)
http://www.vso-software.fr/products/vmp ... player.php
Can you post your log file?
I'm using VLC Media Player, and there the converted movie is playing without problems.
But when I'm using the created menus, the player doesn't "jump" to main movie.
There have been some bugs reported with menu navigation in BR players.
I will update this forum thread when a new version is available with fixes for those menu problems.
This new version should fix the problem, can you try it and report back? thanks
http://forums.vso-software.fr/convertxt ... 18184.html
