Frame Rate Issues?
carnage6
Frame Rate Issues?
Post by carnage6 »
Ok I have 2 frame rate issues:
1- When converting I only get conversion rates of 2 FPS so it takes like 30 hours for my project to complete. I have a multicore processor so what gives? How can I fix this?
2- After conversion the frame rate of the completed burned movie has horrible frame lag, stuttering, and skipping. What's up with that? Sucks that I had to waste a BD-R to find out it's no good.
Re: Frame Rate Issues?
Please post your log files...
Thank you.
carnage6
Post by carnage6 »
Is this the correct log?
05:56:31.164 ------------ ****vsoVideoConverter.exe:5984 Log session stop after 2 day(s) 3 hour(s) 4 minute(s) 41 second(s) 240 millisecond(s)****
03:23:06.169 Info Starting to burn converted files...
03:23:06.167 Info Total converted files size: 3.39 Gb.
03:23:05.372 Info Menu built successfully
03:22:28.416 Info Building TITLE menu
00:23:06.690 Info [ ] Loop playback
00:23:06.689 Info [x] Play titles one after the other
00:23:06.688 Info [ ] Don't create title menu for single video
00:23:06.688 Info [x] Return to title menu after titleset playback
00:23:06.687 Info [ ] Skip root menu initially
00:23:06.686 Info [x] Auto-start playback
00:23:06.686 Info Template: Black Mirror with video in top 1/3 of screen in root menu, contains 4 page(s)
00:23:06.686 Group Blu-ray/AVCHD menu options
00:23:06.685 Info Output target size : BD-25 (23000 MB)
00:23:06.684 Info Number of core(s) used for encoding : 8
00:23:06.684 Info Number of core(s) used for decoding : 8
00:23:06.683 Info [x] Use 2 pass encoding
00:23:06.683 Info [x] Use best video quality settings
00:23:06.682 Info [ ] Use hardware encoding (if possible)
00:23:06.682 Info [ ] Use hardware decoding (if possible)
00:23:06.681 Info Max simultaneous conversions: 8
00:23:06.681 Group Advanced encoding options
03:22:28.291 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
03:17:49.804 Info Menu built successfully
^^^Repeated 5 Times in 4 minute(s) 38 second(s) 483 millisecond(s)^^^
03:16:27.068 Info Building ROOTCHAPTERS, menus using template: Black Mirror with video in top 1/3 of screen in root menu
^^^Repeated 2 Times in 2 millisecond(s)^^^
03:16:26.958 Info video #1 - Processed video frames: 238371 (238369 frames encoded, 1 frames dropped, 0 frames duplicated)
04:40:00.641 Info First pass done
00:23:06.767 ------------ +--> [audio #2 - RAW copy]
+-[audio [eng] ac3 main audio 6 Ch., 48000 Hz, 384 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 18790 Kbps [en]]
+-[video [eng] h264 1912x796 245:102 yuv420p, 23.98 fps, 0 Kbps]
Output file: C:\Users\Paul\Documents\VSO Video Converter\transformers.age.of.extinction.2014.1080p.web-dl.dd51\AVCHD\BDMV\STREAM\00000.m2ts (AVCHD structure)
Input file: c:\users\paul\videos\transformers.age.of.extinction.2014.1080p.web-dl.dd51.h264.mkv
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: linear (vso). Fit method: automatic (Padding: top: 82, bottom: 82, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 124, right: 124)
00:23:06.766 Info Chapters to generate: 22
00:23:06.678 Info Added in conversion queue list...
00:23:06.675 Warning Reached font size limit, text truncated from "transformers.age.of.extinction.2014.1080p.web-dl.dd51.h264" to "SNAP_MM_CLUSTER_TAG"
00:23:06.674 Info Menu fit: Text size reduced from 26.00 to 20.00 in style "caption"
00:23:06.614 Info Menu fit: Text size reduced from 36.00 to 28.00 in style "title"
00:23:06.422 Group ******************** Titleset #1 - ~165 min. File: "transformers.age.of.extinction.2014.1080p.web-dl.dd51.h" -> 00000.m2ts - AVCHD structure ********************|GK_TITLESET|
00:23:06.421 Info Encoding options: Short Projects (Automatic)
00:23:06.421 Info Target size: 22.85 Gb.
00:22:58.292 Group Conversion to "HD structures AVCHD 1080p" started at 12:23:06 AM: 1 sequence(s) to encode|GK_CONVERT_SESSION|
03:23:31.898 Info Disc ejected by user.
03:23:27.703 Error An error occured in burning process. Drive status code: 1.
03:23:27.696 Error INIT ERROR: Input path (C:\Users\Paul\Documents\VSO Video Converter\transformers.age.of.extinction.2014.1080p.web-dl.dd51\BDMV) is empty.
03:23:26.931 Info Volume ID: transformers.age.of.extinction.2014.1080p.web-dl.dd51
03:23:26.925 Info Folder: C:\Users\Paul\Documents\VSO Video Converter\transformers.age.of.extinction.2014.1080p.web-dl.dd51\BDMV
03:23:26.919 Info Write started
03:23:10.858 Info Writable disc dvd-r inserted. Ready to write
03:23:08.796 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
03:23:08.796 Info Drive has Serial ATA physical interface
03:23:08.795 Info New Drive selected : 0 - HL-DT-ST BD-RE WH10LS30 1.00 [D:]
00:18:50.693 ------------ ************************vsoVideoConverter.exe:5984 Log session start 2014-10-04 at 00:18:50.658*************************
Try changing ALL these settings to exactly opposite.
Currently you are converting slowest possible - 2-pass and best video with no hardware.
I started to convert that movie and got over 70FPS with i5 CPU and GTX660Ti.
carnage6
Post by carnage6 »
Ok I'll try that but I would have thought 2 pass encoding and best video settings were used to prevent things like that from happening which is why I turned them on.
And - you do not need to burn, check conversion result with software player before burning to be sure that it is converted ok.
