AVCHD Burns as a data disc
renits
Post by renits »
I have just converted a movie and when it goes to burn it burns the content on to the disc as as data file not as a straight up AVCHD disc.i am currently using ConvertXtoHD alpha version v1.0.0.7.
If i was to do the same file in ConvetXtoDVD with the same box checked (burn to disc) the dvd will play as soon as i put it in the bluray player.
will attach log.
Cheers
Renits
ConvertXtoHD 1_mainlog_.20141022.171452.372.log
(9.97 KiB) Downloaded 446 times
Re: AVCHD Burns as a data disc
Hello renits,
This problem will be fixed in next beta version...
Thank you for your feedback.
