Not able to download episode videos
LCData1701
Post by LCData1701 »
I had been using a 3.x version of the program ok, but when that was failing after theblaze did an update, I grabbed the latest (v4.2.2.3) to see if it would help things. It still grabs the free video ok, but on the subscriber side yesterday it wouldn't get anything, and then today it's pulling a set of files like 15.mpeg, 59.mpeg, etc. (and they are very small). I believe this site uses some of the same technology that mlb uses, if that helps any.
Suggestions for how to alleviate this? I've not yet bought the full version, but I would be happy to if this can be fixed :)
- Jonathan
Re: Not able to download episode videos
LCData1701 wrote: but on the subscriber side yesterday it wouldn't get anything, and then today it's pulling a set of files like 15.mpeg, 59.mpeg, etc. (and they are very small). I believe this site uses some of the same technology that mlb uses, if that helps any.
Can you send us the link please?
And FYI latest version is now 4.2.3.0 but I am uncertain if it will change anything for this case, but try it and let us know.
LCData1701
Sure...here are a couple of examples..
link that fails
http://www.video.theblaze.com/video/v36 ... ck-program
link that succeeds
http://www.video.theblaze.com/video/v36 ... -continues
LCData1701
I downloaded & installed the latest version (which curiously when I checked for updates w/in the program it didn't suggest there was one). Regardless, now it can still download free clips, but ones that require an account don't get "confused" & grab the random numbered files. Now it simply grabs nothing. So it's cleaner, but still not functioning for the paid portion of the web site. Is there any other information I can provide?
Do at any point do you see a balloon hint like this one, see image:
http://oasis.vso-software.fr/claire/dow ... nglish.jpg
LCData1701
Claire wrote:Do at any point do you see a balloon hint like this one, see image:
I haven't seen that while trying from the Blaze site, but I have seen that pop up when I'm watching or downloading Youtube videos w/ a separate program.
LCData1701
I just grabbed the latest version (v4.2.4.1) and it no longer grabs the multiple random 2 digit numbered videos, but still won't detect the subscription-based videos (only the free clips).
Benjamin
Post by Benjamin »
with the latest version (4.2.5.1) I have no problem to download from this site, your link is not workink any more:
LCData1701
Benjamin wrote:with the latest version (4.2.5.1) I have no problem to download from this site, your link is not workink any more:
I can still get to the link above when I'm logged into the site, but here's a new link to a show from Monday:
http://www.video.theblaze.com/video/v37 ... ck-program
I'm using the same version (4.2.5.1), and when I go to that link it downloads multiple short video files with names like 59.mpeg, 04.mpeg, 09.mpeg, 14.mpeg (and then I stopped it at this point).
In case it helps, this is the page where that show link was located:
http://www.video.theblaze.com/schedule/ ... d=20150105
And it temporarily hits the following link before resolving to the one above:
http://www.video.theblaze.com/video/e187-217088/
Benjamin
Post by Benjamin »
I think you need to be logged to load this video, if you want help send me your logins by private message.
Benjamin
Post by Benjamin »
thanks for your logins, I confirm you need to be logged to view this video:
for videos that need registration the server uses the HLS protocol that is not yet supported (we plan to support it this year).
LCData1701
Benjamin wrote:thanks for your logins, I confirm you need to be logged to view this video:
Ah! That must be what they (or MLB) changed to late last year. Thanks for your diligence into looking trying this out for me. I certainly look forward in the future to being able to download & watch at higher speeds instead of the 1X streaming again! I'll be watching for those updates in the meantime.
