I have a registered version 4.2.3.0 of VSO downloader
It does not detect streams from the following UK television sites.
itv
channel4
channel5
There are no pop-up dialogues declaring errors.
Can you advise if these will be available in future versions of the software.
Stream not detected
Re: Stream not detected
Hopefully yes they will be supported in the future, but probably not for the next 6 months...
