How does one buy this
Exfso
Post by Exfso »
I have just downloaded the Beta version. When I click on the page to buy, there is no link to ConvertXtoHD, so how does one purchase it, no idea of the cost either!!!
Re: How does one buy this
Name was just changed on last beta, previous name was Video Converter.
http://www.vso-software.fr/products/vid ... verter.php
If you buy from that link, keycode will work for beta also.
Exfso
Post by Exfso »
So what you are saying is that Video converter is actually ConvertXtoHD?? or does a key for video converter work for the latter!!!
igor_lvk
Post by igor_lvk »
Exfso wrote:I have just downloaded the Beta version. When I click on the page to buy, there is no link to ConvertXtoHD, so how does one purchase it, no idea of the cost either!!!
Link for buying https://secure.avangate.com/order/check ... wPopup=yes
Exfso wrote:So what you are saying is that Video converter is actually ConvertXtoHD?? or does a key for video converter work for the latter!!!
No - Video Converter changed name to ConvertXtoVIDEO - not ConvertXtoHD, that is another product. Name was changed most likely to keep them uniform.
And yes, you are correct, there is no easy link on VSO site for ConvertXtoHD as it is totally new product and still in beta.
Like igor_lvk posted, there is link to buy it, but it is ONLY on top post here:
http://forums.vso-software.fr/convertxt ... 18184.html
Exfso
Post by Exfso »
OK, thanks for that. Must admit it does seem rather strange paying for a Beta version. I can only assume it is almost ready for final release. :!:
ConvertXtoHD is now officially in our shop http://www.vso-software.fr/shop.php
