I've just ripped "The Hobbit 2" from BR which has DTS-HD MA 7.1.
I'm using the following profile
---- Output container informations ----
* Name: M2TS (Blu-ray)
* File extension: m2ts
---- VIDEO track informations ----
Video stream will be encoded using these settings:
* codec: mpeg2video
* framerate: Same as source (if compatible)
* width: Same as source (if compatible)
* height: Same as source (if compatible)
* aspect ratio: Same as source (if compatible)
---- AUDIO tracks informations ----
Audio streams will be encoded using these settings:
* codec: ac3
* channel count: Same as source (if compatible)
* samplerate: Same as source (if compatible)Hz
---- SUBTITLE tracks informations ----
Subtitle streams will be encoded using these settings:
* Embed in video stream
and finally I get
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2h 41mn
Bit rate mode : Constant
Bit rate : 512 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -42ms
Stream size : 591 MiB (4%)
Language : German
It sounds really horrible on the TV.
I'm not an expert but isn't it possible that VSO converter uses the next lower format ... DTS HD MA 7.1 into AC3 5.1 (6 channels), when I'm right?
Update:
I've selected copy (remux) in the profile:
If possible, audio streams will be copied (remuxed).
Otherwise, they will be encoded using these settings:
* codec: ac3
and now it will be converted into AC3 6 channels?
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1mn 48s
Bit rate : 512 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 6.65 MiB (4%)
Language : German
How that?
When it is not possible to copy then 6 channels will be used.
When I explicity use AC-3 (copy/remux not selected) ?, I only get 2 channels?
Is this correct or is it only too late for me tonight? ;-)
Thanks!
DTS-HD MA 7.1 converts into AC3 Stereo
Re: DTS-HD MA 7.1 converts into AC3 Stereo
I have the same problem.
All DTS sound ends up in 2 channel stereo. Dont know how long this has been going on, just realized that the sound on the latest rip was really bad so I started looking in to it. All rips a couple of months back are screwed.
Running on 3.5.0.10 now but just upgraded last week or so, so this was happening in older versions as well....
Using profiles MKV-H264 and AVI-H264 with the same results.
I'm also wondering if I'm missing something here...
Please, can you try with the last beta version?
Thank you!
Thank you!
Hi Claire,
I've installed the latest beta but can't test it (at the moment) because I've lent it a friend. I hopefully get it tomorrow.
Currently I don't have another blu-ray with DTS 7.1.
I'm sure it will work. :-)
THANKS!
THANKS!
did you get it back, how did the conversion go?
