Last CXHD beta version 1.0.0.29
Latest beta version 1.0.0.29: no beta, see latest official below
http://oasis.vso-software.fr/Beta/ConvertXtoHD/
Latest official version on ConvertXtoHD product page :
version 1.0.0.29 http://www.vso-software.fr/products/convert-x-to-hd/
Change log:
ConvertXtoHD - 1.0.0.28 (Released 2015-01-26) [ View Issues ]
- 0009318: [Bug] "open folder" button does not work in overwritting dialogue (cedric) - resolved.
- 0009316: [Bug] During rendering the tiny thumbnail-size window on the left side is becoming GREEN every 3 seconds or so (cedric) - resolved.
- 0009315: [Bug] no thumbnail appears in treeview with particular flv (cedric) - resolved.
- 0009310: [Bug] does not use ASS subtitle settings of input file (cedric) - resolved.
- 0009307: [Bug] In some cases burning window is transparant - makes it hard to burn (cedric) - resolved.
- 0009306: [Bug] Option to allow not Blu-ray/AVCHD compliant framerates not always applied (encoder use default 24p) (cedric) - resolved.
[6 issues]
Please post bugs found in this new version here in this thread.
Change log:
[6 issues]
Re: Last CXHD beta version 1.0.0.24
Hi there. I am loving the latest versions of this program but am having a little problem. All the processing, burning etc.. seems to go extremely well but when I play the resulting BluRay the chapter skip doesn't seem to work with the video. The image freezes but the sound continues as if the chapter skip is fine. Most peculiar. Also, menu screens seem to load and then the disc jumps and reloads the menu screen again. This happens with EVERY menu screen. This has happened with EVERY disc I have burned, both 25Gb and 50Gb, single movies and multiple movies. As I say, most peculiar.
Many thanks for the excellent program thus far however.
A very happy New Year to all the team :)
Strange errors again with hardware decoding. Haven't any with previous release.
Advanced encoding options
21:31:45.564 Error [decoder][h264]: hardware accelerator failed to decode picture
21:31:45.562 Error [decoder][h264]: decode_slice_header error
21:31:45.560 Error [decoder][h264]: Missing reference picture, default is 0
21:31:45.558 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GTX 590, vendor 0x10DE (NVIDIA), device 0x1088, revision 161
21:31:45.487 Error [decoder][aac]: Prediction is not allowed in AAC-LC.
- ConvertXtoHD 1_mainlog_.20150106.213152.595.log
- (7.44 KiB) Downloaded 515 times
Re: Last CXHD beta version 1.0.0.25
it makes some blocks shapes on the blue-ray on the new one for what i watch in the front i put four movies and check the first one blocks in the video not much there mp4 files i used and i thought trying this one it as fixed i put 720p files and 720p output at least its watchable
Please, can you explain your problem more precisely?it makes some blocks shapes on the blue-ray on the new one for what i watch in the front i put four movies and check the first one blocks in the video not much there mp4 files i used and i thought trying this one it as fixed i put 720p files and 720p output at least its watchable
Can you post your log files?
Thank you.
both my asus bw 16d1ht V1.01 plus my old asus blue ray writer say they don't work properly the program says the DVD ROM is incompatible both covertxtohd and convertxtodvd but it still burns them with a few glitches
found out have a blue-ray burning problem 009 set tip problem it won't burn anything blue-ray mp4 it it has read error problems it crashes the blue-ray burning
log files please...
Pan and Scan not working. Can't get rid of the black bars in 21:9 movies. Can someone help? Thanks.
I am sorry. It seemed that the video was actually 1920x1080p, so that the black bars were part of it and hadn't been added by the media player. So ConvertXtoHD didn't know where to pan and scan... I guess i have to resize to 1920x800 to get rid of them. Thanks anyway. I am posting the solution so that users with the same problem might be helped.
Handbrake detects the black bars automatically, even in that case (the video is 16:9 AND with black bars). Why your software doesn't? And why there isn't a manual pan and scan option? If I select manual pan and scan, I cannot change the values. The only thing I can do manually is stretch.
DVD work OK but my copy of converttohd blue-rays have problems they wont burn it does not tell me why have the latest version and after the conversion is finished i checked to see if everything is set up alright have it on 25gig blue-ray all works well until the burn it just does not burn the file mp4
Can everyone please post the log of their conversion. It provides very useful information to the members who can help as well as to the devs who write/edit the software.
Thanks for reading,
Neil M
Thanks for reading,
Neil M
Re: Last CXHD beta version 1.0.0.26
Big mistiming between audio and video when encoding from 29.97 to 23.98. And video plays very slowly.
Please, post your log files...
Here it is, Cedric.
- ConvertXtoHD 1_mainlog_.20150123.181658.611.log
- (7.57 KiB) Downloaded 495 times
Your inital reported problem should be fixed for the next version, but I can see that you always get the "H.264 preset superfast not found"!
I don't know why you get this warning, I will try to change the source code to handle this problem for the next version too...
Thank you for providing the log file.
I've got this warning when hardware h264 encoding not used.cedric wrote:Your inital reported problem should be fixed for the next version, but I can see that you always get the "H.264 preset superfast not found"!
Re: Last CXHD beta version 1.0.0.27
The new fps options are a good idea. Black borders still not detected. And something else about the subtitles: the recommended font size is very small. If i select
a new font size the program automatically breaks the texts, even in the case that the subtitle actually fits the screen without breaking. There should be a subtitle auto-breaking disable option I think. The user should be responsible if the text is out of screen.
Glitches when converting 25GB mkv to fit in a Single Layer BD-R. The output is 22.6GB and "jumpy".
