Conversion Time ? ? ?
HC1Gunner
Post by HC1Gunner »
Running with a fast i7 Quad-core, and set priority to "Time critical" it says its going to take 12 hours? ? ? Started it before I went to bed last night, sure enough CovertXto HD is still running. Conversion is to Full 1080p.
Chevyguy85
Re: Conversion Time ? ? ?
Post by Chevyguy85 »
With my 8320 OC'd to 4.56 ghz a 1080 blu-ray rip to 1080 blu-ray takes me 8-9 hours. I get anywhere from 5-12 fps when I look. Unlike xtoDVD xtoHD uses all 8 cores and if it's on "time critical" I can't really do much on my computer. The priority settings if I remember right shouldn't really matter if you're leaving your computer alone to do it's thing. If you're not running anything else or using it while it converts then windows has nothing to prioritize.
Settings:
Target size of 23000
Single Pass
Auto resize to keep source AR
Fast linear
Fast linear
H264 hardware decoding
Allow more than 1 hardware encoder...
I can't check the hardware encoding box, it's greyed out.
Takes a while but it works. Just have to be patient.
HC1Gunner
Post by HC1Gunner »
Then for my reward, I ended up with a coaster. Plays and freezes 5 seconds in. I was able to do a time search, and start it further into the movie, sometimes it would play, and sometimes it would freeze. But if it did play there was NO audio, so a complete failure and waste of time.
Hello HC1Gunner,
Please can you post your conversion log file?
Thank you.
HC1Gunner
Post by HC1Gunner »
So far I'm unable to locate that file.
logs are stored automatically here
C:\ProgramData\VSO\ConvertXtoHD\1\Log
