1.0.0.23 Issue, or ??
u2olds
Post by u2olds »
I seem to be running into an issue with the last couple of updates. Maybe its on my end, but I wanted to throw this out there to make sure.
I will say about 80% through the movie's, they start to freeze. They will clear up, and the movie finishes. I am using Verbatim BD-25's and burn at 2x.
Is it something someone else has ran into? Thank you for any help:)
budies3
Re: 1.0.0.23 Issue, or ??
Post by budies3 »
What happens when you burn a regular dvd?
u2olds
Post by u2olds »
The DVD's have no issue's so far, it only seems to be the BD. Maybe I'm the only one with this problem?
Copnm
Post by Copnm »
Hello u2olds,
Have you tried using the latest beta version after doing a fresh/clean install? Also, can you please post the log of your conversion.
Thanks for reading,
Neil M
I also received your request via our technical support. Thanks.
It is not clear to me what the problem is exactly.
The conversions and the burning completes?
You talk about freezing around 80% when does the freezing happen? During the conversion, the burning or when you watch the final result (if so where, on your computer your blu-ray living room player?)?
Around the 90% of the conversion you may notice a slow down in the conversion speed as at this point this is when the menus are being generated and they can be more time consuming cpu intensive than when converting the actual videos (it depends on the menu template you choose).
Give us a little more info about where exactly the problem lies and hopefully we can help get things running smoother.
budies3
Post by budies3 »
His BD are freezing, about 80% into watching them. This is not an issue on dvd's, just the Blu-Ray's.
That might be a problem with burner. Burn heads are separate for CD, DVD and BR.
