I can't install ConvertXtoHD 1.0.0.28b !
Ben Richard
Post by Ben Richard »
Hi all,I'm new member
I have just installed ConvertXtoHD 1.0.0.28b on my computer but can't succeed.I must press "Ignore" continuosly ( I tried press "Retry" but can't succeed ! ) . I used software Cute Screen Recorder to record totally the installing process to a MKV file.I compressed it to a RAR file (which is the attachment of this comment).Please download it to your computer,extract it and then watch that MKV file and tell me the reason as soon as possible.I have used Windows 7 Ultimate 32-bit.
I can't install ConvertXtoHD 1.0.0.28 beta on Windows 7 Ultimate 32-bit.rar
(18.45 MiB) Downloaded 379 times
Re: I can't install ConvertXtoHD 1.0.0.28b !
Your setup file is corrupted.
Delete the file, and download it again.
Ben Richard
Thank JJ,but I re-downloaded and then tried to re-install 5 times more but the results are the same : I still can't install this version.It is very strange that I can install version 1.0.0.23 successfully.So I think the problem is at the setup file.VSO software team,please check your ConvertXtoHD 1.0.0.28b setup file and then provide the fixed setup file for me.Thanks.
Reply me soon
Ben Richard
new default download on our website, can you see if you can download it please
1.0.0.29 http://www.vso-software.fr/products/convert-x-to-hd/
Well, right before I wrote my reply I downloaded that version, 1.0.0.28b and installed it without problems.
I would not have answered that otherwise!
Ben Richard
I downloaded latest version 1.0.0.29 and have just installed it successfully.Well,that's good.Thanks all.
