Last CXHD beta version - 1.0.0.37
Latest beta version 1.0.0.37:
http://oasis.vso-software.fr/Beta/Conve ... .0.37b.exe
Latest official version on ConvertXtoHD product page :
version 1.0.0.37 http://www.vso-software.fr/products/convert-x-to-hd/
Please post bugs found in this new version here in this thread.
Change log:
ConvertXtoHD - 1.0.0.37 (Released 2015-02-23) [ View Issues ]
- 0009485: [Bug] Tree refresh problem when selecting Blu-ray menu template (cedric) - resolved.
- 0009482: [Bug] menu font changes conflict - changes not always taken into account (felicia) - resolved.
- 0009480: [Bug] DVD structure not interpreted the same as in VLC (felicia) - resolved.
- 0009474: [Bug] CX2HD always encode to fps that source has. Option of encoding to 25, 30 and above not taken in account (cedric) - resolved.
- 0009473: [Bug] hard to do cut sections when working with long video files (felicia) - resolved.
[5 issues]
Change log:
[5 issues]
Re: Last CXHD beta version - 1.0.0.31
it's working good latest stable its not beta anymore on the website having fun
With v1.0.0.29 my title menus were full-screen 16:9
The same project under v1.0.0.31 the menus are distorted 4:3 letterboxed.
Please fix, or tell me what I've got to change.
Cheers, Chris
Cheers, Chris
Hello owdjim,
Please post your log files.
Re: Last CXHD beta version - 1.0.0.32
No video fps CxHD shows while encoding. And no video in output. Only audio.
Changing the font size is ignored by CXHD. CXHD uses always the default font size for conversion (tested with classic, simple but elegant menu tamplate / preview shows correct font size).
Sample log attached.cedric wrote:Hello owdjim,
Cheers, Chris
- ConvertXtoHD 1_mainlog_.20150211.161054.674.log
- (17.48 KiB) Downloaded 569 times
the frame rate is not shown but at 720p it only takes 17.50 min is that new or a glitch ill see if the movies play
it's going warp speed have four movies at 720p it took less time than 1 hour or two hope it works i like this speed sure hope it's not a glitch
hope you fix this soon it does not play the movie just sticks
on one frame out of sink for the blue ray lost a blue ray yucky program it's really hosed up
this update is realy bad sticks now moving of picture the sound is out of sink damn its bad
i hope you fix this soon went back 1 0 0 31
found out the problem it's going at 60fps my tv supports but not my bluray player i think try to find a solution to this problem
it only burnt a little on the blue ray there's probably know video
Re: Last CXHD beta version - 1.0.0.33
i hope this one is beater than the last trying it out it seams OK when i convert 17 fps on 720p movies two at a time frames are there and it seams stable now hope i don't lose another blue ray thanks for fixing the problem so fast
a bit glitched square blocks to problems in the movies i burnt cant burn a 2x so beater burn. it goes up to 4x
you half to change it to 2x when your about to burn
that was the problem glitches because i did not burn at 2x
Conversion of this project now fails under 1.0.0.33b with "unable to initialize menu" errors. Log file with error attached.owdjim wrote:Sample log attached.cedric wrote:Hello owdjim,
Cheers, Chris
Cheers, Chris
- ConvertXtoHD 1_mainlog_.20150213.212211.199.log
- (15.29 KiB) Downloaded 525 times
thanks for reporting this will be solved in the next version
will be fixed in the next versionJAL wrote:Changing the font size is ignored by CXHD. CXHD uses always the default font size for conversion (tested with classic, simple but elegant menu tamplate / preview shows correct font size).
