3 problems converting ABBA-Super Trouper Deluxe Edition DVD
3 major problems converting ABBA - Super Trouper Deluxe Edition DVD
Tested with 3.5.0.21 + 3.5.0.23 (Beta)!
I've just bought all Deluxe Editions from ABBA (8 DVDs!) and want to convert the DVD (music videos) as MP4, H264, AAC-44100-Stereo-384000.
Problem 1:
Crash during the start of the process: "An error occured while converting."
I have prepared my own profile
<?xml version="1.0" encoding="Windows-1252" standalone="no"?>
<Configuration>
<VSO_custom_profile>
<Description/>
<DefaultFileExtension>mp4</DefaultFileExtension>
<ContextName>DVD Video MP4-H264-AAC-Stereo</ContextName>
<VideoProfile>
<Item0>codec=h264</Item0>
<Item1>qmax=31</Item1>
<Item2>qmin=2</Item2>
<Item3>qdiff=3</Item3>
<Item4>coder=0</Item4>
<Item5>trellis=0</Item5>
<Item6>mixed-refs=0</Item6>
<Item7>dct8x8=0</Item7>
<Count>8</Count>
</VideoProfile>
<AudioProfile>
<Item0>codec=aac</Item0>
<Item1>ar=44100</Item1>
<Item2>ac=2</Item2>
<Item3>ab_by_channel=384000</Item3>
<Count>4</Count>
</AudioProfile>
<SubtitleProfile>
<Count>0</Count>
</SubtitleProfile>
<ImageIndex>16</ImageIndex>
<TemplateName>Custom profiles</TemplateName>
<editor_link>FALSE</editor_link>
<OutputFolder>M:\Videos\00_Check-In\4661282\DVD1</OutputFolder>
<Container>Sm_Mp4</Container>
</VSO_custom_profile>
</Configuration>
but after pressing start the error occurs.
Mediainfo from a .vob file of the DVD shows:
General
Complete name : D:\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 20mn 41s
Overall bit rate : 6 916 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Format settings, picture structure : Frame
Duration : 20mn 41s
Bit rate : 6 400 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.618
Time code of first frame : 01:00:00;00
Time code source : Group of pictures header
Stream size : 947 MiB (92%)
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 20mn 41s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 56.8 MiB (6%)
Any idea?
Problem 1:
<Configuration>
<Description/>
<VideoProfile>
<Count>8</Count>
</VideoProfile>
<AudioProfile>
<Item2>ac=2</Item2>
<Count>4</Count>
</AudioProfile>
<SubtitleProfile>
<Count>0</Count>
</SubtitleProfile>
</Configuration>
General
Format : MPEG-PS
Duration : 20mn 41s
Video
Format : MPEG Video
Duration : 20mn 41s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Audio
Format : AC-3
Duration : 20mn 41s
Bit rate : 384 Kbps
Bit depth : 16 bits
Any idea?
Re: 3 problems converting ABBA-Super Trouper Deluxe Edition
Problem 2:
My feature request about the default path in a profile is not fully done!
Only one folder can be specified for ALL music DVDs. Which means the next music DVD also converts the files into the same directory. Each DVD should be converted into a subfolder of the root path (defined in the profile) - the same logic as in the general settings!
Problem 3:
DVD title: 1 h 19 m = over 20 music videos in 26 chapters.
The killer feature request to store each chapter into a single files becomes more and more important. As DJ & collector I need the single files of course.
I tried the "Advanced Edit" to convert only one chapter but I would have to disable all other chapters to get one chapter. Finally when I want convert 20 videos (from these 26 chapters) I have to disable 25 chapters per video and confirm the deletion too: 20 x 25 x 2 = 1000 and more mouse clicks for one DVD! :-(
Selection markers instead of remove buttons would be easier to use - but of course single files is much more useful to convert all in one go.
so you mean and also "add project name in path"?dosibo51 wrote:Problem 2:
confirmed your problem, bug reporteddosibo51 wrote: Problem 1:
http://bugs.vso-software.fr/view.php?id=9372
We've already made not of your feature requestdosibo51 wrote:Problem 3:
http://bugs.vso-software.fr/view.php?id=9112
Yes. I mean the drop down box "Output folder generation". Currently all files of a DVD will be stored into the root folder as defined in the profile. The next DVD also stores into the same location. So currently after converting I have to manually move the files into a sub folder. (e.g. my profiles are DVD children cartoon, DVD children film, DVD Music Videos, DVD Films, ... different hard discs, different root folders). You could also take the option from the general settings but (read below) if you add an option "Open Explorer" it should be a drop down box for each profile.Claire wrote:so you mean and also "add project name in path"?dosibo51 wrote:Problem 2:
Only one folder can be specified for ALL music DVDs. Which means the next music DVD also converts the files into the same directory. Each DVD should be converted into a sub folder of the root path (defined in the profile) - the same logic as in the general settings!
I'm also missing the information of the path in the final "Step 5 SAVE":
Only
Code: Select all
---- Output container informations ----
* Name: Mpeg2-TS
* File extension: ts
I would also find it useful if the overview text is identical as in the settings of the profile. Instead of "Name: Mpeg2-TS" it should be "File format (container): Mpeg2-TS".
And finally I'm missing "Custom profile name" in the overview.
Another very useful option for the drop down box "Output folder generation" would be "Open Explorer". When the START button will be pressed, Explorer should open to choose the final path. Start path for the Explorer should be the path of the profile or general settings.
THANKS A LOT
added as a feature request hereYes. I mean the drop down box "Output folder generation".
http://bugs.vso-software.fr/view.php?id=9379
added as a feature request hereAnother very useful option for the drop down box "Output folder generation" would be "Open Explorer". When the START button will be pressed, Explorer should open to choose the final path. Start path for the Explorer should be the path of the profile or general settings.
http://bugs.vso-software.fr/view.php?id=9380
andAnd finally I'm missing "Custom profile name" in the overview
added as a feature request in same bug report herealso missing the information of the path in the final "Step 5 SAVE":
http://bugs.vso-software.fr/view.php?id=9381
added hereI would also find it useful if the overview text is identical as in the settings of the profile. Instead of "Name: Mpeg2-TS" it should be "File format (container): Mpeg2-TS".
http://bugs.vso-software.fr/view.php?id=9382
many bugs and feature requests made in this thread have been solved in this new beta version
http://forums.vso-software.fr/newconver ... 18405.html
