For a while I've been using ConvertXtoDVD v5.2.0.42 to create discs with multi-page menus,
eg I'm using the "VSO glossy template, blue background, up to 2 episodes/titles per page" with
four titles. This gives two menu pages with two titles per page, all navigating correctly.
I'm now trying to do the same thing but with ConvertXtoHD.
All my conversion, burning & playback is going ok, but with one annoying difference.
With ConvertXtoDVD if I play a title on "page 2" of the menu my player returns to
"page 2" at the end of a title playing.
However, with ConvertXtoHD if I play a title on "page 2" my player always returns to
"page 1" of the menus, not to the "current" page. This can be annoying if there are multiple pages.
Is this something that can be fixed? Or is it inherent in Blu-ray menus?
I've tried ConvertXtoHD v1.0.0.29 and .31 beta, tried "classic" & "minimal" templates
but all show the same behaviour.
Cheers, Chris
Multi-page menus?
Re: Multi-page menus?
Thank you for the feedback.
An issue has been created http://bugs.vso-software.fr/view.php?id=9400, we will tell you as soon as it's fixed
Best regards,
Felicià
Best regards,
Felicià
This version should correct the problem, please let us know your results
http://forums.vso-software.fr/last-cxhd ... 18520.html
Looks like it's working fineClaire wrote:Hello,
Thanks!
Cheers, Chris
fantastic, thanks for letting us know!
