ConvertXtoVideo - latest beta version (1.5.0.28)
Latest beta version (1.5.0.28) :
http://oasis.vso-software.fr/Beta/AllVS ... .0.28b.exe
Latest official (stable) version is 1.5.0.28:
http://www.vso-software.fr/products/vid ... -video.php
FYI - we published a new version again today feb 24th but with the same version number as of last friday - sorry for this error, new changes have been made
ConvertXtoVideo - 1.5.0.28 (Released 2015-02-24) [ View Issues ]
- 0009481: [Bug] DVD structure not interpreted the same as in VLC (felicia) - resolved.
- 0009465: [Bug] odd behavior of preview when making a 2nd cut this time at start of video (cedric) - resolved.
- 0009462: [Bug] quality advisor has a black background (cedric) - resolved.
- 0009463: [Bug] removing merged file in advanced editor does not remove associated subtitle streams (cedric) - resolved.
- 0009464: [Bug] moving cut section does not work if created at the beginning of a video (cedric) - resolved.
- 0009466: [Suggestion] option "open explorer" to choose output path when conversion started, but if you press cancel conversion starts anyway (cedric) - resolved.
- 0009461: [Bug] can't add srt (cedric) - resolved.
scorpion90
Re: ConvertXtoVideo - latest beta version (1.5.0.26)
Post by scorpion90 »
I am getting a lot of access violation messages when I attempt to make an mkv from blu-ray folder. See attached pic. It is happening with Blu-ray Converter Ultimate also.
[attachment=0]access violation.jpg[/attachment]
Access violation
Access violation
scorpion90
scorpion90 wrote:I am getting a lot of access violation messages when I attempt to make an mkv from blu-ray folder. See attached pic. It is happening with Blu-ray Converter Ultimate also.
The latest version .27b solved the access violation issues. The software is not correctly identifying Dolby Digital True HD audio stream..it incorrectly identifies it as DD AC3 (it shows AC3 Complete in the remux while interrogating the original .m2ts shows DD True HD). Same thing with Bluray Converter Ultimate.
Please take a look at why it's not showing and remuxing the full DD True HD stream.
Many thanks,
windale
Re: ConvertXtoVideo - latest beta version (1.5.0.28)
Post by windale »
My Profile - Advanced Settings
Can't change the 'Video Aspect Ratio' yet again for about the 6th time !! Please fix it and maybe test your program before sending out 20 beta's that keep needing the same bugs fixed over and over again. Thanks. Sorry for the rant but it's annoying when the same bugs keep coming back after you said you fixed them 5 times already.
in the custom profile editor?
Hello windale,
What type of custom profile are you making? (container, video/audio codecs...)
Can you post it?
Why do you want to specify an aspect ratio?
windale
(Official 1.5.0.28)
Post by windale »
Custom Profile
Any Container
The Aspect Ratio line is always greyed out (this has happened on many previous versions from what i've read in these forums). I try to choose any resolution and it won't let me change the aspect ratio.
Aspect Ratio Doesn't Work AGAIN.jpg (26.31 KiB) Viewed 13122 times
I have a movie that is stretched to 16:9 but I want to convert it to 4:3. At the end of the day, the option doesn't work.
I'm using version 1.5.0.28 (Not Beta).
If you want a 4/3 output aspect ratio, why do you select a 16/9 output resolution in custom profile editor (1920x1080)?
windale
Post by windale »
That was just a screenshot to show that the Aspect Ratio option doesn't work (on any resolution).
Aspect Ratio Doesn't Work AGAIN_002.jpg (29.91 KiB) Viewed 13108 times
Thanks for confirming. This will be fixed in the next version.
