No Main Menu
bootlegger3
No Main Menu
Post by bootlegger3 »
I took my dvd season 2 of breaking bad and put it on one blu ray. This is my fourth time I made the disc from ISO images, I have 13 episodes that went on to the menu. After just changing the episode names, I previewed every episode and the main menu I then converted and burned. I took the Blu Ray disc and I tried it in my Blu Ray Player it would show BD-R BDMV try to start and not do anything. My Blu Ray is an older Sony.
I then tried it in VSL, VSO Player and Power DVD......all three play the Blu Ray starting at the 1st episode, not at the menu. When trying to go to the menu to pick an episode, as it would be on a stand alone player, the screen goes gray. I can play every episode, but it will not give me a menu. I figure this is why it will not work in my Sony Stand Alone
I checked the stream folder and the main menu is in there, it just will not come up.
I have the latest edition of x to Hd..............it shows that the project is 21.GB.
I'm using Verbatim BD-R discs 25GB
I did burn the first season with only 7 episodes and that worked...........confused
:std_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_mainlog_.20150210.063430.574.log'
:library=false
:app_name=ConvertXtoHD.exe
:app_version=1.0.0.31
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
06:34:30.074 ------------ **********ConvertXtoHD.exe:7976 Log session stop after 6 hour(s) 42 minute(s) 58 second(s) 686 millisecond(s)***********
06:34:27.070 Info Project "C:\Users\Owner\Documents\BlindWrite\Breaking Bad Season 2.XtoHD" saved.
03:26:52.757 Info Total size 21960 Mb., Target size Custom 23000 Mb., Occupation 95.48%
06:34:21.277 Info Disc name: "Breaking Bad Season 2"
03:26:53.313 Info Burned folder: "C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2", Min. media size 21.4 Gb.
03:26:52.735 Info Conversion completed in 03:23:00
03:25:49.071 Info "TITLE" menu built successfully
^^^Repeated 5 Times in 59 second(s) 528 millisecond(s)^^^
03:25:32.046 Info Building TITLE menu
00:03:55.697 Info [ ] Loop playback
00:03:55.693 Info [ ] Play titles one after the other
00:03:55.689 Info [x] Don't create title menu for single video
00:03:55.686 Info [x] Return to title menu after titleset playback
00:03:55.682 Info [x] Skip root menu initially
00:03:55.678 Info [ ] Auto-start playback
00:03:55.674 Info Template: Black Mirror, contains 4 page(s)
00:03:55.674 Group Blu-ray/AVCHD menu options
00:03:55.671 Info Output target size : Custom value (23000 MB)
00:03:55.667 Info Number of core(s) used for encoding : 4
00:03:55.663 Info Number of core(s) used for decoding : 4
00:03:55.660 Info [ ] Use 2 pass encoding
00:03:55.656 Info [ ] Use best video quality settings
00:03:55.653 Info [ ] Use hardware encoding (if possible)
00:03:55.648 Info [ ] Use hardware decoding (if possible)
00:03:55.645 Info Max simultaneous conversions: 4
00:03:55.645 Group Advanced encoding options
03:25:31.492 ------------ *****************************************File encoded successfully: 00012.m2ts******************************************
03:25:31.474 Info "SETTINGS" menu built successfully
03:25:22.099 Info "CHAPTERS" menu built successfully
03:24:54.065 Info "ROOT" menu built successfully
03:24:44.652 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Black Mirror
^^^Repeated 2 Times in 23 millisecond(s)^^^
03:24:44.572 Info video #1 - Processed video frames: 68460 (68521 frames encoded, 28 frames dropped, 90 frames duplicated)
02:59:08.344 ------------ +--> [audio #3 - RAW copy]
+-[audio [eng] ac3 main audio 2 Ch., 48000 Hz, 192 Kbps]
+--> [audio #2 - RAW copy]
+-[audio [eng] ac3 main audio 6 Ch., 48000 Hz, 448 Kbps]
+--> [video #1 - h264 video, 1280x720, yuv420p, 16x9, 24.00Fps, 4100 Kbps [un]]
+-[video mpeg2video 720x480 16:9 yuv420p, 59.94 fps, 9800 Kbps]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00012.m2ts (Blu-ray)
Input file: c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_4.iso
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
02:59:08.321 Info Chapters to generate: 7
00:03:55.632 Info Added in conversion queue list...
00:03:55.552 Group ******************** Titleset #13 - ~47 min. File: "Episode 13" -> 00012.m2ts - Blu-ray ********************|GK_TITLESET|
03:06:44.103 ------------ *****************************************File encoded successfully: 00011.m2ts******************************************
03:06:44.082 Info "CHAPTERS" menu built successfully
03:05:52.593 Info "ROOT" menu built successfully
03:05:36.733 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
^^^Repeated 2 Times in 25 millisecond(s)^^^
03:05:36.543 Info video #1 - Processed video frames: 68213 (68276 frames encoded, 28 frames dropped, 92 frames duplicated)
02:07:37.179 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00011.m2ts (Blu-ray)
Video filters used:
02:07:37.164 Info Chapters to generate: 7
00:03:55.473 Info Added in conversion queue list...
00:03:55.394 Group ******************** Titleset #12 - ~47 min. File: "Episode 12" -> 00011.m2ts - Blu-ray ********************|GK_TITLESET|
03:02:41.768 ------------ *****************************************File encoded successfully: 00010.m2ts******************************************
03:02:41.756 Info "CHAPTERS" menu built successfully
03:01:46.455 Info "ROOT" menu built successfully
03:01:29.761 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
03:01:29.517 Info video #1 - Processed video frames: 68146 (68209 frames encoded, 24 frames dropped, 88 frames duplicated)
02:03:53.931 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00010.m2ts (Blu-ray)
Video filters used:
02:03:53.917 Info Chapters to generate: 7
00:03:55.316 Info Added in conversion queue list...
00:03:55.238 Group ******************** Titleset #11 - ~47 min. File: "Episode 11" -> 00010.m2ts - Blu-ray ********************|GK_TITLESET|
03:06:54.779 ------------ *****************************************File encoded successfully: 00009.m2ts******************************************
03:06:54.771 Info "CHAPTERS" menu built successfully
03:06:07.252 Info "ROOT" menu built successfully
03:05:51.968 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
^^^Repeated 2 Times in 14 millisecond(s)^^^
03:05:51.881 Info video #1 - Processed video frames: 68437 (85201 frames encoded, 0 frames dropped, 16765 frames duplicated)
02:03:32.362 Warning Encoding using a not Blu-ray/AVCHD compliant 29.97Fps source framerate (allowed by user settings)
02:03:32.329 ------------ +--> [audio #2 - RAW copy]
+--> [video #1 - h264 video, 1280x720, yuv420p, 16x9, 29.97Fps, 4100 Kbps [un]]
+-[video mpeg2video 720x480 16:9 yuv420p, 29.97 fps, 9800 Kbps]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00009.m2ts (Blu-ray)
Input file: c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_3.iso
Video filters used:
02:03:32.314 Info Chapters to generate: 7
00:03:55.158 Info Added in conversion queue list...
00:03:55.080 Group ******************** Titleset #10 - ~47 min. File: "Episode 10" -> 00009.m2ts - Blu-ray ********************|GK_TITLESET|
02:59:07.654 ------------ *****************************************File encoded successfully: 00008.m2ts******************************************
02:59:07.640 Info "SETTINGS" menu built successfully
02:58:50.832 Info "CHAPTERS" menu built successfully
02:57:58.302 Info "ROOT" menu built successfully
02:57:39.174 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Black Mirror
02:57:38.994 Info video #1 - Processed video frames: 68415 (85176 frames encoded, 0 frames dropped, 16762 frames duplicated)
02:02:57.082 Warning Encoding using a not Blu-ray/AVCHD compliant 29.97Fps source framerate (allowed by user settings)
02:02:57.048 ------------ +--> [audio #3 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00008.m2ts (Blu-ray)
Video filters used:
02:02:57.032 Info Chapters to generate: 7
00:03:55.001 Info Added in conversion queue list...
00:03:54.921 Group ******************** Titleset #9 - ~47 min. File: "Episode 9" -> 00008.m2ts - Blu-ray ********************|GK_TITLESET|
02:03:53.208 ------------ *****************************************File encoded successfully: 00007.m2ts******************************************
02:03:53.200 Info "SETTINGS" menu built successfully
02:03:33.829 Info "CHAPTERS" menu built successfully
02:02:21.088 Info "ROOT" menu built successfully
02:01:54.812 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Black Mirror
^^^Repeated 2 Times in 20 millisecond(s)^^^
02:01:54.653 Info video #1 - Processed video frames: 68412 (85181 frames encoded, 0 frames dropped, 16770 frames duplicated)
01:04:27.138 Warning Encoding using a not Blu-ray/AVCHD compliant 29.97Fps source framerate (allowed by user settings)
01:04:27.115 ------------ +--> [audio #3 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00007.m2ts (Blu-ray)
Video filters used:
01:04:27.101 Info Chapters to generate: 7
00:03:54.842 Info Added in conversion queue list...
00:03:54.763 Group ******************** Titleset #8 - ~47 min. File: "Episode 8" -> 00007.m2ts - Blu-ray ********************|GK_TITLESET|
02:07:36.179 ------------ *****************************************File encoded successfully: 00006.m2ts******************************************
02:07:36.163 Info "CHAPTERS" menu built successfully
02:06:33.101 Info "ROOT" menu built successfully
02:06:13.956 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
^^^Repeated 2 Times in 8 millisecond(s)^^^
02:06:13.862 Info video #1 - Processed video frames: 68412 (85176 frames encoded, 0 frames dropped, 16765 frames duplicated)
01:01:48.135 Warning Encoding using a not Blu-ray/AVCHD compliant 29.97Fps source framerate (allowed by user settings)
01:01:48.078 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00006.m2ts (Blu-ray)
Input file: c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_2.iso
Video filters used:
01:01:48.066 Info Chapters to generate: 7
00:03:54.681 Info Added in conversion queue list...
00:03:54.600 Group ******************** Titleset #7 - ~47 min. File: "Episode 7" -> 00006.m2ts - Blu-ray ********************|GK_TITLESET|
02:03:31.932 ------------ *****************************************File encoded successfully: 00005.m2ts******************************************
02:03:31.900 Info "CHAPTERS" menu built successfully
02:02:20.524 Info "ROOT" menu built successfully
02:01:58.666 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
02:01:58.510 Info video #1 - Processed video frames: 68451 (85196 frames encoded, 0 frames dropped, 16746 frames duplicated)
00:58:36.240 Warning Encoding using a not Blu-ray/AVCHD compliant 29.97Fps source framerate (allowed by user settings)
00:58:36.225 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00005.m2ts (Blu-ray)
Video filters used:
00:58:36.204 Info Chapters to generate: 7
00:03:54.521 Info Added in conversion queue list...
00:03:54.441 Group ******************** Titleset #6 - ~47 min. File: "Episode 6" -> 00005.m2ts - Blu-ray ********************|GK_TITLESET|
02:02:56.162 ------------ *****************************************File encoded successfully: 00004.m2ts******************************************
02:02:56.146 Info "CHAPTERS" menu built successfully
02:01:46.782 Info "ROOT" menu built successfully
02:01:20.864 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
^^^Repeated 2 Times in 42 millisecond(s)^^^
02:01:20.539 Info video #1 - Processed video frames: 68425 (85171 frames encoded, 0 frames dropped, 16747 frames duplicated)
00:55:40.218 Warning Encoding using a not Blu-ray/AVCHD compliant 29.97Fps source framerate (allowed by user settings)
00:55:40.194 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00004.m2ts (Blu-ray)
Video filters used:
00:55:40.177 Info Chapters to generate: 7
00:03:54.361 Info Added in conversion queue list...
00:03:54.280 Group ******************** Titleset #5 - ~47 min. File: "Episode 5" -> 00004.m2ts - Blu-ray ********************|GK_TITLESET|
00:55:39.924 ------------ *****************************************File encoded successfully: 00003.m2ts******************************************
00:55:39.901 Info "CHAPTERS" menu built successfully
00:54:33.661 Info "ROOT" menu built successfully
00:54:13.837 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
^^^Repeated 2 Times in 10 millisecond(s)^^^
00:54:13.665 Info video #1 - Processed video frames: 68219 (68281 frames encoded, 28 frames dropped, 91 frames duplicated)
00:03:55.785 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00003.m2ts (Blu-ray)
Input file: c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_1.iso
Video filters used:
00:03:55.781 Info Chapters to generate: 7
00:03:54.202 Info Added in conversion queue list...
00:03:54.121 Group ******************** Titleset #4 - ~47 min. File: "Episode 4" -> 00003.m2ts - Blu-ray ********************|GK_TITLESET|
01:01:47.308 ------------ *****************************************File encoded successfully: 00002.m2ts******************************************
01:01:47.285 Info "CHAPTERS" menu built successfully
01:00:33.546 Info "ROOT" menu built successfully
01:00:14.155 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
^^^Repeated 2 Times in 11 millisecond(s)^^^
01:00:14.011 Info video #1 - Processed video frames: 67630 (67694 frames encoded, 22 frames dropped, 87 frames duplicated)
00:03:55.791 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00002.m2ts (Blu-ray)
Video filters used:
00:03:55.759 Info Chapters to generate: 7
00:03:54.043 Info Added in conversion queue list...
00:03:53.964 Group ******************** Titleset #3 - ~47 min. File: "Episode 3" -> 00002.m2ts - Blu-ray ********************|GK_TITLESET|
00:58:35.219 ------------ *****************************************File encoded successfully: 00001.m2ts******************************************
00:58:35.199 Info "CHAPTERS" menu built successfully
00:57:27.839 Info "ROOT" menu built successfully
00:57:07.707 Info Building ROOT & CHAPTERS, menus using template: Black Mirror
00:57:07.407 Info video #1 - Processed video frames: 69011 (69074 frames encoded, 34 frames dropped, 98 frames duplicated)
00:03:55.777 ------------ +--> [audio #2 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00001.m2ts (Blu-ray)
Video filters used:
00:03:55.751 Info Chapters to generate: 7
00:03:53.886 Info Added in conversion queue list...
00:03:53.806 Group ******************** Titleset #2 - ~47 min. File: "Episode 2" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
01:04:26.930 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
01:04:26.916 Info "SETTINGS" menu built successfully
01:04:03.350 Info "CHAPTERS" menu built successfully
01:02:52.910 Info "ROOT" menu built successfully
01:02:34.241 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Black Mirror
^^^Repeated 2 Times in 7 millisecond(s)^^^
01:02:34.099 Info video #1 - Processed video frames: 67995 (68057 frames encoded, 34 frames dropped, 97 frames duplicated)
00:03:55.806 ------------ +--> [audio #3 - RAW copy]
Output file: C:\Users\Owner\Documents\ConvertXtoHD\Breaking Bad Season 2\BDMV\STREAM\00000.m2ts (Blu-ray)
Video filters used:
00:03:53.725 Info Added in conversion queue list...
00:03:53.644 Group ******************** Titleset #1 - ~47 min. File: "Episode 1" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
00:03:53.552 Info Encoding options: Long Project (Automatic)
00:03:53.549 Info Target size: 22.5 Gb.
00:03:52.340 Info Don't log FFMpeg log events
00:03:52.337 ------------ ***************************************************Burn settings end****************************************************
00:03:52.334 Info Default speed selected: 4x
00:03:52.331 Info [ ] Delete vsomsl files after burn complete
00:03:52.329 Info [ ] Delete output folder after burn complete
00:03:52.326 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
00:03:52.324 Info SAO setting: Automatic
00:03:52.321 Info [x] Burn result to disk / as ISO file in working folder
00:03:52.319 ------------ **************************************************Burn settings begin***************************************************
00:03:52.319 Group Encoding session started at 12:03:52 AM: 13 titleset(s) to encode -> Completed in 03:23:00|GK_CONVERT_SESSION|
23:51:58.607 Info Build OK
23:51:58.604 Info Source is OK
23:51:58.601 Info Media loaded
23:51:58.574 Group Loading structure
23:51:58.512 Group Loading structure
23:51:58.093 Info Build OK
23:51:58.091 Info Source is OK
23:51:58.089 Info Media loaded
23:51:58.061 Group Loading structure
23:51:57.998 Group Loading structure
23:51:57.603 Info Found features
23:51:57.352 Info Build OK
23:51:57.350 Info Source is OK
23:51:57.348 Info Media loaded
23:51:57.315 Group Loading structure
23:51:57.249 Group Loading structure
23:51:56.782 Info Found features
23:51:56.416 Info Build OK
23:51:56.414 Info Source is OK
23:51:56.413 Info Media loaded
23:51:56.380 Group Loading structure
23:51:56.366 Group Loading structure
23:51:59.000 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_4.iso"
23:51:58.996 Group Titleset #13 - ~47 min. File: "Episode 13" successfully loaded.
23:51:58.987 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_4.iso"
23:51:58.978 Group Titleset #12 - ~47 min. File: "Episode 12" successfully loaded.
23:51:58.969 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_4.iso"
23:51:58.494 Group Titleset #11 - ~47 min. File: "Episode 11" successfully loaded.
23:51:58.486 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_3.iso"
23:51:58.482 Group Titleset #10 - ~47 min. File: "Episode 10" successfully loaded.
23:51:58.474 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_3.iso"
23:51:58.463 Group Titleset #9 - ~47 min. File: "Episode 9" successfully loaded.
23:51:58.454 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_3.iso"
23:51:57.980 Group Titleset #8 - ~47 min. File: "Episode 8" successfully loaded.
23:51:57.971 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_2.iso"
23:51:57.967 Group Titleset #7 - ~47 min. File: "Episode 7" successfully loaded.
23:51:57.958 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_2.iso"
23:51:57.948 Group Titleset #6 - ~47 min. File: "Episode 6" successfully loaded.
23:51:57.939 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_2.iso"
23:51:57.231 Group Titleset #5 - ~47 min. File: "Episode 5" successfully loaded.
23:51:57.223 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_1.iso"
23:51:57.218 Group Titleset #4 - ~47 min. File: "Episode 4" successfully loaded.
23:51:57.210 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_1.iso"
23:51:57.205 Group Titleset #3 - ~47 min. File: "Episode 3" successfully loaded.
23:51:57.197 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_1.iso"
23:51:57.185 Group Titleset #2 - ~47 min. File: "Episode 2" successfully loaded.
23:51:57.175 Info Restored file "c:\users\owner\documents\blindwrite\breaking_bad_season_2_disc_1.iso"
23:51:56.325 Group Titleset #1 - ~47 min. File: "Episode 1" successfully loaded.
23:51:55.922 Warning File "C:\Users\Owner\Documents\BlindWrite\Breaking Bad Season 2.XtoHD" was created with an earlier version, re-save it with this version to update.
23:51:55.690 Group Project in "C:\Users\Owner\Documents\BlindWrite\Breaking Bad Season 2.XtoHD" loaded successfully
23:51:32.711 Info Menu templates loaded: 36
23:51:30.079 Info Total Physical Memory : 3581 Mb.
Available Physical Memory : 1926 Mb.
Memory Load : 46%
Available Virtual Memory : 3821 Mb.
Total Memory : 7161 Mb.
Available Memory : 4674 Mb.
23:51:30.079 Info Processor AMD Athlon(tm) II X4 640 Processor with 4 core(s) CPU
Supported instruction set: MMX,ExMMX,3DNow!,Ex3DNow,sse,sse2 (slow),sse3,sse4A
23:51:30.070 Info OS : Windows 7 (64 bits), Build 7601, service pack 1.0
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXtoHD.exe
file version : 1.0.0.31
23:51:28.739 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
23:51:28.737 ------------ ***************************ConvertXtoHD.exe:7976 Log session start 2015-02-09 at 23:51:28.384***************************
03:53:14.694 Info WRITE SUCCESS: Disc written
03:53:13.178 Info Burning process completed successfully.
03:53:13.166 Info Finalization Time 32s1232ms - Total completion time 25m59s1259ms
03:53:13.135 Info Finalise: Finalisation completed
03:53:13.124 Info Finalise: Close disc - Completed
03:52:59.054 Info Finalise: Start Close media
03:52:59.041 Info Finalise: Close session - Completed
03:52:56.519 Info Finalise: Start Close session
03:52:56.508 Info Finalise: Close track - Completed
03:52:43.949 Info Finalise: Start Close track
03:52:43.929 Info Finalise: Flush device cache - Completed
03:52:40.399 Info Finalise: Flushing burner cache
03:52:40.386 Info Write finished in 25m26s1226ms - Finalization start here. Avg. burn rate 3.36
03:52:40.370 Info Finalise: Start disc finalisation
03:27:35.317 Info WRITING: Lead-in burning time required 21s1221ms
03:27:13.773 Info Write started 11245504 sectors to write
03:27:13.767 Info Init BD-R: Success
03:27:13.763 Info Write speed set at x4.0 (17984 kB/s) CAV
03:27:11.571 Info Available write speed: x6.0 (26976 kB/s) CAV *, x4.0 (17984 kB/s) CAV, x2.0 (8992 kB/s)
03:27:11.566 Info Media ID: VERBAT-IMe-7D
03:27:11.466 Info Scanned files #387, folder #15 - total size 23026999419 b. (21.4 Gb.)
03:27:11.461 Info Inserted media type : bd-r sequential recording
03:27:11.453 Info Volume ID: Breaking Bad Season 2
03:27:11.449 Info Folder: C:\USERS\OWNER\DOCUMENTS\CONVERTXTOHD\BREAKING BAD SEASON 2\
03:27:11.444 Info Write started
03:27:09.569 Info Blu-ray/AVCHD structure burn process started
23:54:27.236 Info Writable disc bd-r sequential recording inserted. Ready to write
^^^Repeated 2 Times in 3 hour(s) 32 minute(s) 28 second(s) 20 millisecond(s)^^^
23:54:15.099 Info Parsing disc ...
23:53:42.955 Info Disc ejected by user.
23:51:31.364 Info Disc blu-ray is not compatible for write with this drive.
23:51:28.734 Info 2 writer(s) found.
23:51:28.731 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
23:51:28.728 Info Drive has Serial ATA physical interface
23:51:28.726 Info New Drive selected : HL-DT-ST BD-RE BP50NB40 1.00 (USB)
23:51:28.692 Group Burn engine events
Re: No Main Menu
This may be fixed in the latest beta can you please try with it and report back
http://forums.vso-software.fr/last-cxhd ... 18520.html
