BR/DVD Converter 4, new BETA version! 4.0.0.61
Latest official versions: 4.0.0.60
Latest beta version 4.0.0.61
Blu-ray Converter : http://download.vso-software.fr/archive ... 0.0.61.exe
DVD Converter : http://download.vso-software.fr/archive ... 0.0.61.exe
Last beta version changes:
Blu-ray & DVD Converters - 4.0.0.61
- 0012810: [Bug] Wrong message when trying to load a deleted file from history (felicia) - resolved.
- 0012745: [Bug] target size not respected converting to blu-ray (felicia) - resolved.
- 0012806: [Crash] Program crashes if too many simultaneous conversions are requested (felicia) - resolved.
- 0012804: [Bug] Title issue when converting to structure (felicia) - resolved.
- 0012802: [Bug] log shows incorrect value of output size (felicia) - resolved.
- 0012800: [Bug] problem with listing of chapter points in final menu and in advanced editing window - happens only with some blu-rays (felicia) - resolved.
- 0012792: [Bug] "operation complete" does not play if burning (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.60
- 0009124: [Bug] cant scroll to bottom of log (felicia) - resolved.
- 0009254: [Bug] film is pixalized with bad sound in preview and output (felicia) - resolved.
- 0012788: [Bug] Quick settings not applyed until program restarts (felicia) - resolved.
- 0012786: [Bug] Missing description for some disc items (felicia) - resolved.
- 0012778: [Information] improve speed of audio normalization (felicia) - resolved.
- 0012783: [Bug] conversion fails with some audio streams with "convert dts to ac3" UN-checked (felicia) - resolved.
- 0012763: [Feature Request] Remember log form position & size (felicia) - resolved.
- 0012769: [Bug] Error while loading particular Blu-Ray (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.59
- 0012757: [Bug] Can't write to ISO in working directory. (felicia) - resolved.
- 0012754: [Bug] don't create a folder here during installation C:\Users\[user name]\Documents\ (felicia) - resolved.
- 0012750: [Bug] output folder default path is version specific and should not be (felicia) - resolved.
- 0012683: [Suggestion] check writing rights when user selects output folder (felicia) - resolved.
- 0012740: [Feature Request] when creating custom profile be able to create folder for when using "use a custom output folder when using this profile" (cedric) - resolved.
- 0012739: [Bug] Changing watermark font does not work (cedric) - resolved.
Blu-ray & DVD Converters - 4.0.0.58
- 0012708: [Bug] tolerate DVD subtitle in custom made MP4 profiles (felicia) - resolved.
- 0012710: [Bug] Program crashes if setting forced subtitles when in spanish (felicia) - resolved.
- 0012697: [Bug] Video stream discarded in favor of attached pict (felicia) - resolved.
- 0012690: [Bug] Tree popup menu items stay enabled during conversion (felicia) - resolved.
- 0012675: [Bug] Code page selector does not stay open (felicia) - resolved.
- 0012669: [Bug] advanced subtitles window can open up in with odd display of settings stretched out (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.57 (Released 2017-02-23) [ View Issues ]
- 0012572: [Bug] conversion crashes when adding external sub/idx added (felicia) - resolved.
- 0012659: [Bug] display message user tries to load more than 99 videos and DVD profile is selected (felicia) - resolved.
- 0012612: [Bug] advanced editor window is always 'on top' even if open a web browser window for example or anything else (felicia) - resolved.
- 0012520: [Bug] subtitles stay on screen until the next (felicia) - resolved.
- 0012613: [Feature Request] add hint also to drop down selection in subtitle editor (felicia) - resolved.
- 0012568: [Bug] Issue with Smallville DVDs (felicia) - resolved.
- 0010951: [Information] navigate using arrows in global settings does not update display in left panel (felicia) - resolved.
- 0012582: [Bug] app hangs after a successful conversion/burn - must kill with task manager (felicia) - resolved.
- 0012140: [Feature Request] add new file renaming method special for when converting several episodes so each have a specific name (felicia) - resolved.
- 0012565: [Bug] hint takes up too much room (felicia) - resolved.
- 0012509: [Bug] simultaneous conversion not working with particular blu-ray (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.56 (Released 2017-02-01) [ View Issues ]
- 0012555: [Crash] app freezes when trying to load Blu ray (felicia) - resolved.
- 0012546: [Bug] not correctly identifying of the videos on the disk - being mislabled (felicia) - resolved.
- 0012507: [Bug] conversion fails with particular blu-ray source (felicia) - resolved.
- 0012526: [Bug] encoder crash: Pro Res codec (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.55 (Released 2017-01-24) [ View Issues ]
- 0012517: [Bug] some Blu-ray's as ISO don't open (wesson) - resolved.
- 0012478: [Bug] wrong number of audio channels sometimes displayed (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.53 (Not Yet Released) [ View Issues ]
- 0012394: [Bug] loop playback not applied with FLV videos (felicia) - resolved.
- 0012395: [Bug] redo a conversion to DVD format (overwriting previous conversion) and subtitles will be black (felicia) - resolved.
- 0012396: [Bug] changing resize filter in advanced edit, change is not saved (felicia) - resolved.
- 0012348: [Suggestion] change default menu for all outputs menu related (DVD, AVCHD + Blu-ray) as users complain of slowness or not completing (felicia) - resolved.
- 0012384: [Bug] conversion error trying to convert TrueHD to DTS (felicia) - resolved.
- 0010097: [Bug] DVD Converter hangs up during analyzing a specific Music DVD (felicia) - resolved.
- 0012356: [Feature Request] Add option to cancel file parsing (felicia) - resolved.
Blu-ray & DVD Converters - 4.0.0.52 (Released 2016-12-15) [ View Issues ]
- 0012310: [Bug] Audio streams are not remuxed even if I create a DVD/Blu-ray custom remux profile (cedric) - resolved.
[1 issue]
Blu-ray & DVD Converters - 4.0.0.51 (Released 2016-12-08) [ View Issues ]
- 0012291: [Bug] Buttons are missing in cut/chapters tab if Windows big fonts are used (cedric) - resolved.
[1 issue]
Blu-ray & DVD Converters - 4.0.0.50 (Released 2016-11-30) [ View Issues ]
- 0012280: [Bug] Getting output size overflow with DVD/Blu-ray and AVCHD output profiles (cedric) - resolved.
- 0012278: [Bug] Bad aspect ratio on output when "Remove balck bars" function is used (cedric) - resolved.
[2 issues]
Blu-ray & DVD Converters - 4.0.0.49 (Released 2016-11-24) [ View Issues ]
- 0012271: [Bug] "PAL Auto" and "NTSC Auto" profiles not working if input file aspect is not 4/3 or 16/9 (cedric) - resolved.
[1 issue]
[1 issue]
[1 issue]
[2 issues]
[1 issue]
Re: BR/DVD Converter latest BETA version - 3.5.0.32
Installed v.32 and now get an error message on the home screen whenever I select an option box. See attached picture of error. Went back to v.31 with no error codes.
[attachment=0]Error Screen.jpg[/attachment]
we see the problem it will be fixed soon, sorry about it and thanks for reporting
http://bugs.vso-software.fr/view.php?id=9610
Re: BR/DVD Converter latest BETA version - 3.5.0.36
now fixed in new version
Re: BR/DVD Converter latest BETA version - 3.6.0.3
I just installed BR 3.6.0.3 and tried to convert "Games of Thrones Season 2 Disc1" but after "hard reading" in the BR drive - the START button is only greyed out for more than 5 minutes now (BR drive stopped reading in the meantime).
See screen shot:
Update:
With 3.5.0.36 all works fine - see screen shot:
See screen shot:
Update:
Just downloaded 3.6.0.4 from download site ... In Help / About it is only 3.6.0.3 .. and tried to convert blu-ray "Games of Thrones" Season 2 Disc 3 ...
Analyzing the disc hangs up BR converter ... as I wrote above.
See also screen shot:
Have to make a step back to 3.5.0.36.
thanks for this info about the website not being in sync with the actual download.
in a couple of hours, normally the new downloads will be actually updated with 3.6.0.4 and we did make a change (although not noted in the change log) that will hopefully correct this loading problem you informed us of
I catched 3.6.0.4 this morning and tried it - but does not work.
I have recorded a video what happens. I will send you a download link via support.
In the meantime I still have to use 3.5.0.36.
Re: BR/DVD Converter latest BETA version - 3.6.0.4
ok darn, thanks so much. We will check it out on Monday.
Re: BR/DVD Converter latest BETA version - 3.6.0.5
After further investigation together with user, solution was to enable the setting in AnyDVD
"remove video sequence shorter than .. 20 minutes"
3.6.0.5 of Blu-ray Converter works very good with this solution
OK, in the newest version it will no longer let me convert more than one video at a time.
In settings it still shows allow 4 conversions at one time. But, leaves 3 in queue and does them one at a time.
Thanks for your report that should be because you were converting from a disk in your optical drive, is that correct?
We made this change
- 0009824: [Suggestion] when converting from a physical disk limit to only one titleset at a time, no simultaneous conversions (cedric) - resolved.
To avoid other bugs that could happen.
Maybe we should ad an entry to the log to inform users... ?
We made this change
Yes, I am loading from virtual drives. (Daemon Tools Lite)
Thanks for reporting, we will correct this in a future version.
Re: BR/DVD Converter latest BETA version - 3.6.0.7
Ok, still having issues with more than one conversion at a time with virtual drives and now also can't change name of file prior to recording.
What do you mean? Where? I seem to be able to do this fine.LivingBeaverton wrote:Ok, still having issues with more than one conversion at a time with virtual drives and now also can't change name of file prior to recording.
as for the virtual drive problem can you post a conversion log please?
Re: BR/DVD Converter latest BETA version - 3.6.0.8
I stopped the conversion after realized still not converting more than one file at a time when using virtual drives.
- DVD Converter Ultimate 3_crashlog_.20150522.143448.302.log
- Log
- (4.85 KiB) Downloaded 1478 times
Re: BR/DVD Converter latest BETA version - 3.6.0.9
LivingBeaverton's problem is now solved in 3.6.0.9 - thanks for helping us work this out.
Re: BR/DVD Converter latest BETA version - 3.6.0.17
With 3.6.0.16 (but I'm sure .17 will not fix the problem) ...
DVD Converter hangs up during analyzing the music DVD http://www.discogs.com/Frankie-Goes-To- ... se/1367384 ... Start button always greyed out (can't be clicked anymore - waited over 2 hours ...).
When in preferences / chapters / Create on titleset per chapters ... is enabled.
This only happens with this music DVD. I've tried another music DVD (from Falco) - works.
See screen shot enclosed
I hope this can be fixed ... maybe remote on my PC again on Monday late afternoon?
