I'm using the trial version of this software (I already own ConvertXtoDVD) and I can't figure out how to create a menu for multiple videos.
Edit: I'm trying out ConvertXToHD and it has the option to create a menu.
How do I add a menu?
Re: How do I add a menu?
In ConvertXtoHD an menu is created automatically. ConvertXtoHD works just like ConvertXtoDVD.
Here is a guide
http://www.vso-software.fr/guides/how-t ... -to-hd.php
Here is a guide
I had this posted in "ConvertXtoVideo" because that was the program I was trying to create a menu in.
Someone moved my post from there to "ConvertXtoHD"
I assumed there is no way to create a menu in ConvertXtoVideo so I tried out ConvertXtoHD.
A menu is created in ConvertXtoVideo if you convert to Blu-ray AVCHD, or DVD but you cannot edit it like in ConvertXtoDVD or ConvertXtoHD.
