I have several MTS files from my camcorder, and I want to make AVCHD Progressive discs with menu without reencoding.
The file is 1920x1080p, 50 fps, 28 Mbit/s.
AVCHD 2.0 Specification is on wikipedia (1920x1080 50 fps or 59.94 fps progressive, up to 28 Mbit/s).
When I creating a custom profile with container "AVCHD (for optical disc)", the result is always reencoded.
When I select the "MTS (AVCHD)" container, the remux is working, but the result is simple files, not disc with menu.
Cedric created a custom AVCHD Remux profile for me, but not working with the new versions (the file is attached).
I make a test disc with MultiAVCHD without reencoding and I tested with several bluray players (LG, Samsung, Pioneer) and it's working fine.
Please add support for this.
Please add support for AVCHD 2.0 disc
- AVCHD remux.zip
- (679 Bytes) Downloaded 298 times
Re: Please add support for AVCHD 2.0 disc
Hello djnice,
Reproduced/fixed for the next beta version (will be published today).
Thank you for reporting back.
Thank you!
I tried, and it's working!
