I was wondering what is the most preferred and popular resize filter that most use when converting media files to Blu-Ray using ConvertXtoHD.
I do know on ConvertXtoDVD, the resize filter Lanczos was the most popular setting when converting media files to DVD.
What is the most preferred and popular resize filter on this program for Blu-Ray converting that will give the best video quality?
Thank you in advance for feedback.
Most popular resize filter for convert to Blu-Ray?
Re: Most popular resize filter for convert to Blu-Ray?
Does nobody know what is the most preferred resize filter when using this program to make a Blu-ray?
I have always used resize filter Lanczos since using ConvertXtoDVD but when using
this program, a different resize filter might be better for Blu-ray.
This is why I am asking here.
You can do some tests on your side, but I think Lanczos filter is the best one.
Have read the pos from Edmantay here: http://forums.vso-software.fr/filter-co ... 10825.html
It's about the best filter for DVD, but I also have a question about that.
For upsizing he recommend the Mitchell filter.
Is this also the best filter to upsize from 1080i to 1080p with ConvertxToHD ?
