Latest ConvertXtoVideo version - 2.0.0.5
Latest beta version :
no beta version
Latest official (stable) version is 2.0.0.5
https://www.vso-software.fr/products/vi ... -video.php
see https://www.vso-software.fr/products/vi ... istory.php
ConvertXtoVideo - 1.6.0.48 (Released 2016-01-27) [ View Issues ]
- 0010901: [Feature Request] add version number to top of application (cedric) - resolved.
- 0010925: [Bug] Image Enhancement causes white bars on top and bottom / For an other user, totaly broken (cedric) - resolved.
- 0010926: [Bug] In Advanced Editor, if last usage was Image Enhancement, and it re-opens in this tab, it's empty (cedric) - resolved.
- 0010924: [Bug] In Advanced Editor, if you select an Image Enhancement Template, then exit without saving, doesn't reset (cedric) - resolved.
- 0010928: [Bug] Translation string gets cut off (cedric) - resolved.
- 0010950: [Feature Request] when using "remove black bars" and selection output with inherent output resolution defined apply a auto crop (cedric) - resolved.
- 0010900: [Feature Request] AVI output audio stream to be tagged with language info (cedric) - resolved.
- 0010905: [Bug] water mark is accessible (cedric) - resolved.
ConvertXtoVideo - 1.6.0.47 (Released 2015-12-23) [ View Issues ]
- 0010890: [Bug] Main menu items are hidden (tablet display mode used) (cedric) - resolved.
- 0010892: [Suggestion] Disable OpenCL support for Nvidia GPUs (unstable) (cedric) - resolved.
[2 issues]
no beta version
[2 issues]
Re: Latest ConvertXtoVideo beta version - 1.5.0.39
Hello
I just tried to install new version 1.5.0.39. Installation process is working fine, but program CANNOT start after installation (error message that dvd43.dll-file is missing).
So I went back to stable version 1.5.0.36. Now I can start ConvertXtoVideo without problems.
I guess there is a bug in setup-file of new beta version 1.5.0.39.
Thanks for help.
mue.mat
Thanks for help.
mue.mat
Installer file updated on server, can you retry now?
Thank you for your feedback...
Hello again
...now new beta version 1.5.0.39 is working fine.
Thanks a lot for updating the setup file.
Kind regards
mue.mat
Kind regards
mue.mat
If I convert a file using the AVCHD 1080p, the file is being converted with the bitrate 8.64 Mb/s
If I create a custom profile, and choose AVCHD 1080p Optical Disc, it then goes to 6.30 Mbp/s
Them if i create a custom profile, with AVCHD 1080p Optical Disc, and limit the audio bitrate to 448 kb/s, the video goes to JUST 1.75 Mb/s!!!!
It seens there is a bug when we modify the audio bitrate of a custom profile of AVCHD
Oh, and in the AVCHD profile, if there is a DST audio track in the mkv file, if in the custom profile I set it to 448 kbps birate, the converted file will have a AC3 audio track of 640 kbps
Hello Maikel ,
That mean if you set 448Kbps for a 5.1 channels output that will generate a 2688Kbps audio track? (but limited internally by audio codec limits)
I will check this problem today...If I convert a file using the AVCHD 1080p, the file is being converted with the bitrate 8.64 Mb/s
Did you noticied that this audio bitrate setting is a "bitrate by channel"?Oh, and in the AVCHD profile, if there is a DST audio track in the mkv file, if in the custom profile I set it to 448 kbps birate, the converted file will have a AC3 audio track of 640 kbps
But if I set the channel bitrate to 448 kbps, and the file has an AC3 bitrate of 448 and has a DST track of 1536 kbps (MPC-HC info) , the converted file have both audio tracks of 640 kbpsDid you noticied that this audio bitrate setting is a "bitrate by channel"?
I think the 448 kbps track should stay 448 kbps, or am I wrong?
Dont know if MPC-HC shows the total bitrate, or bitrate per channel.
Is There a way to set the total bitrate to 448, instead of per channel?
Others programs, like AVCHDCoder have an option to set the final bitrate of the track.
Like you can set audio channel count as "Same as source" in custom profile, the audio audio bitrate can't be specified as overall.Is There a way to set the total bitrate to 448, instead of per channel?
For example, if you was allowed to specify overall audio bitrate and selected "same as source" for audio channel count setting and you set 448kbps as bitrate:
- if source file is stereo, output bitrate will be 448kbps so, 224Kbps by channel.
- if source file is 5.1, output bitrate will be 448kbps so, 75Kbps by channel.
By setting audio bitrate by channel, we are certain to obtain same audio quality, no matter input audio channel count...
You set 448 kbps BY CHANNEL (overal 2688 kbps), so the encoder has limited audio profile to internal maximum AC3 bitrate (640 kbps)But if I set the channel bitrate to 448 kbps, and the file has an AC3 bitrate of 448 and has a DST track of 1536 kbps (MPC-HC info) , the converted file have both audio tracks of 640 kbps
Do you know if these programs have same audio channel count option "Same as source"?Others programs, like AVCHDCoder have an option to set the final bitrate of the track.
Why did you not enabled "Remux if possible" option in your custom profile (on top of audio codec list)?
That will skip audio encoding process (faster) and you will keep source audio bitrate.
Re: Latest ConvertXtoVideo beta version - 1.6.0.0
Bravo pour cette nouvelle version d'un programme super et en constante amélioration. J'ai testé cette version 1.6.0.0. Je ne trouve pas le moyen d'encoder en H265 et ne vois pas où il est question de Dolby Atmos. En outre, je constate toujours (je l'ai déjà signalé) un problème lorsque je visionne un film dans l'édition avancée. Si la piste son est en DTS HD MA, il y a sans cesse (après une ou deux minutes de fonctionnement normal) des microcoupures du son et des saccades de l'image. Le même phénomène se produit sur VSO Media Player.
Bien cordialement et en espérant que ces quelques remarques vous seront utiles.
Crashing while trying to convert HEVC file.
Bonjour Jema,
Si vous portez attention au "Changelog" on indique
Comme je connais VSO ça va surement être dedans dès que possible
Donc je crois pour l'instant que le logiciel pourra lire et comprendre les fichiers en H265 mais elle ne peux pas en produire (en sortie) pour l'instant.- 0007577: [Feature Request] Add h265/HEVC decoding support (cedric) - resolved.
Hello igor_lvk,igor_lvk wrote:Crashing while trying to convert HEVC file.
Do you have an internet link where we can download the same H265/HEVC files ?
I would personally be very curious on trying the convertion and see which media players plays them (for now)...
Thanks...
Ah yes, does it crash when you try to convert to ANY output, on what output selection did you try ?
Sometimes it crashes when trying 1 specific output, but them works using a different output (for testing...)
Here https://yadi.sk/d/zZBXZP2Rg7qC9Cougar_II wrote:Hello igor_lvk,igor_lvk wrote:Crashing while trying to convert HEVC file.
Thanks...
Hello Igor_lvk,
I have just spoken to the programmers of ConvertXtoVideo and they confirm issues with the H265 decoding.
They are working on it, so let's see when the next builds comes out if they stabilize H265 decoding.
Thanks for your patience...
Sure, no problem. Just waiting as always....Cougar_II wrote:Hello Igor_lvk,
Re: Latest ConvertXtoVideo beta version - 1.6.0.1
New beta version posted, i m waiting for your feedback...
Thank you
Thank you
HVEC decoding fine. But something goes wrong with encoding to dvd video. Got strange errors. Nothing happend before in version 36. Very bad sound.
- ConvertXtoVideo Ultimate 1_crashlog_.20150423.173740.724.log
- (178.92 KiB) Downloaded 604 times
Re: Latest ConvertXtoVideo beta version - 1.6.0.2
Problem still remains with audio. Very bad quality.
It was an installer problem I think... rebuilt now
Can you retry by re-DOWNLOADING then install the last version?
Thank you.
Thank you.
