what does this mean? "first encoding pass done, waiting for
ericc2728
Post by ericc2728 »
remaining titlesets"? i clicked the 2 pass option and now it is just staying there doing nothing, but giving me that message. i tried to cancel also and it isn't canceling. Thanks for your help!
Re: what does this mean? "first encoding pass done, waiting
That is normal behavior with 2-pass.
First is checking the video, then second calculates optimal bitstream.
If you want to use 2-pass, just wait. Most users do not see any difference without it...
ericc2728
Post by ericc2728 »
i waited for an hour and it did nothing, so i canceled it. it just sat there at 50% with the same message. i had both two pass encoding and use best video quality settings checked so i unchecked use best video quality settings and it worked. is there a reason why i can't do both?
It works, second pass with best video quality might take several hours with some systems. There is no progress indicator so you just need to wait.
Hello ericc2728,
Can you please send us your conversion log file?
Thank you.
