Hello again
Unfortunately framerate of video stream in converted video isn't to see any more (f.e. in VLC media player).
I should be to have an easy and quick control if desired framerate came out in converted movie.
In older version framerate was (as it should be) always to see in media player.
Maybe you can also handle this little problem
mue.mat
v1.6.0.0: Framerate in converted movie is "hidden"
Re: v1.6.0.0: Framerate in converted movie is "hidden"
What output format do you used?
Problem resolved!
I have just seen, that only VLC player (after update to version 2.2.1) doen't show any more the video framerate after conversion to BluRay structure.
Other media players do show normally. So the problem is NOT with ConvertXtoVideo.
mue.mat
mue.mat
