Latest beta file size
zebadee
Post by zebadee »
Hi :)
1st time I've had this (in a long time at least).
Re: Latest beta file size
So estimation was much more than actual file?
How is the quality on converted result?
zebadee
Post by zebadee »
Hi :)
Considering file size.
Not bad on mobile.
(Nexus 6)
But I can do better with other s/w.
File size larger , of course.
Another thing it only appears to work on the above BD.
With others the "Start" button greyed out.
zebadee wrote:Hi :)
Not bad on mobile.
(Nexus 6)
Larger? Estimate is 10.7Gb and converted result is 3.42Gb ?
Or what are those pics showing?
I think the start button being greyed out is fixed in the latest beta
http://forums.vso-software.fr/dvd-conve ... 18563.html
Let me know if it is not.
zebadee
Post by zebadee »
Claire wrote:I think the start button being greyed out is fixed in the latest beta
Hi :)
Sorry for late response.
Been trying out all options with all my software.
Still have problem with Alice in Wonderland.
(Only with VSO, all other software works.)
Just to be clear; you want converted filesize to be bigger than what the actual converted result is?
