Audio and Video
slee02
Audio and Video
Post by slee02 »
I have attached the log....
When I do a MediaInfo on the output file....For Xvid (AVI) settings it says Matrix: Default (h.263), profile: Advanced Simple@L1, and I try to do AC3 (6 Channel) audio from DTS or DTS-MA (bluray or dvd).
For audio codec, I get ID:1, and codec ID: 00001000-0000-0020-8000-00AA0389B71, bitrate 640 kbps (no matter what I put in proggy..448, etc.) 6 Channels.
I seem I can't change format profile to: Advanced Simple@L5 or AC3 audio output should be ID:1, and Codec ID:2000
The output I described is unknown to my streaming bluray player. The above codec id:2000 works on my player, not the long 00001000-etc...
ConvertXtoVideo Ultimate 1_mainlog_.20150607.160612.185.log
(6.53 KiB) Downloaded 355 times
Re: Audio and Video
sorry for no answer. I will look into this and try and get back to you.
FYI a new version has since been posted in case you want to try with that.
slee02
Re: Audio and Video
Post by slee02 »
I will try it again with the newest stable version.. and report back...
