Softcoded Subtitles again not working properly
Hello
Again, adding softcoded subtiteles there is missing subtitle text. Hardcoded subtitles are working fine (as usual).
mue.mat
mue.mat
Re: Softcoded Subtitles again not working properly
...and often, after subtitles appear on screen, they do not disappear any more until next part of text comes up. Strange thing...
I should like uninstall latest version and install older version where subtitles are working better.
How can I find the original setup-files for older versions? For example v1.6.0.15 or older?
Thanks for support
mue.mat
Thanks for support
mue.mat
Maybe an important help:
When I try the "neighour" software ConvertXtoHD, the converter software creates smooth softcoded subtitles (for the same movie(s)).
Why ConvertXtoVideo doesn't work if ConvertXtoHD is doing the job well in terms of soft subtitles (electable)?
mue.mat
mue.mat
In ConvertXtoVideo what format are you converting to? Maybe that format doesn't support soft coded subtitles . . .
Converting to BluRay 720p.
But I don't think t's the format.
In former versions, softcoded subtitles were possible. Even now it's possible, but as before described, there are errors (missing text, subtitle "stays" to long on screen).
mue.mat
mue.mat
opps I should have read the earlier post of this thread.
Older versions can be found here (click on the tab "all versions")
http://www.afterdawn.com/software/audio ... l_versions
...you got mail...
thanks received, for now I cannot reproduce.
User reported to be directly, problem solved with a clean installation of the software ![Smile :)](./images/smilies/icon_smile.gif)
