Hi I am using the convertx ultimate converter but I am very confused first of all I want to put films onto a usb stick but do not know which format I normlly use AVI BUT THERE ARE A FEW LIKE AVI H264 +3 i JUST DON'T KNOW
i ALSO use convertxtodvd to convert to dvd
avi or xvid
Re: avi or xvid
It depends on what you are using to watch those films.
If you only use computer, then it does not matter what format you are using and you should select biggest screen available for your playback device.
If you are using any other device then it is totally different issue, depending on what that playing device supports.
