Menu in preview, but not in output
I added 8 videos to my project and chose the classic menu template. The menu shows in the preview window with all 8 movie titles present, but when the project is finished converting all the movies are just in one contiguous stream and there is no menu option.
- ConvertXtoHD 1_mainlog_.20150710.073045.982.log
- Latest log file.
- (52.61 KiB) Downloaded 438 times
Re: Menu in preview, but not in output
Have you tried playing one movie and then pressing the menu button, i see in the log its set to "skip root menu initially" so maybe the menu will only show when one film has finished?
Just a thought
Pete
Just a thought
Pete
Hi Pete,
Thanks for the suggestion. My understanding from the hint text is that "title menu" is the Blu-ray's main menu screen and "root menu" is the main menu of the individual movie. So the option to skip root menu initially shouldn't prevent the Blu-ray's main menu from displaying, only skip the play/chapter/options menu of the individual movie after you select it from the Blu-ray's main menu.
Either way, I have selected the skip root menu option on every Blu-ray I have made and this is the only one that is missing the Blu-ray main menu.
When one movie finishes it simply moves on the to next movie because they appear to have been merged into a single movie file. They are clearly still separate in the Blu-ray's main menu in the preview window, as you can see from the screenshot I included in the OP.
HI,
You do not want to have the option checked "auto start playback" if you want the menu to display when you insert your disk into a player. Also VSO Media Player does not play any menus. You can use PowerDVD or a living room player.
