With v1.6.0.16 it was possible to convert up to 14 episodes (45 min, 720p, BluRay) at the same time (fast hardware encoding, CUDA).
Now, with actual version, three mkv files are already enough to make the software crash after 10 sec.
So that means, I go back again to stable version 1.6.0.16.
At the moment there are a lot of "surprises" with every new version...
mue.mat
v1.6.0.20: crashing, crashing, crashing (Hw Encoding)
Re: v1.6.0.20: crashing, crashing, crashing (Hw Encoding)
...but it might be that converting dts audio is the problem.
I gonna change dts to ac3 and try out...
[Solved] Re: v1.6.0.20: crashing, crashing, (Hw Encoding)
Indeed, converting DTS Audio W A S the problem.
Converting DTS to AC3 (with multiple files) --> v1.6.0.20 is working fine.
mue.mat
mue.mat
Hello mue.mat,
Can you post your log files (with failing conversion)?
...have a look at personal message.
Problem as well happens not only in v1.6.0.20.
It also crashes after conversion (100%), but during building menu.
mue.mat
mue.mat
how about with the latest version 1.6.0.24?
