convertxtohd 1 3 0 21
the bluray file i put 30 files. at 480p to maximize and keep best quality, but after 9 hours it would not burn it wanted it as a data file. tried all my other programs to burn it and it would not burn it's a data file.am i doing something wrong or not?
Re: convertxtohd 1 3 0 21
It must be some kind of bug if it wouldn't burn, unless it was bigger than the disc size. I am sure going to be mad if I try burning one and it takes that long then fails.
Also what confuses me is both in convertxtoDVD and convertxtoHD I have the burn iso file checked yet it always has the folder structure, never have I seen an iso file ever from either program. It has it on the computer as folders of various files.
Did you choose 4/3 or 16/9? I bet you will end up having my same issue if you do ever burn it, where it stretches the picture.
it was at 16/9 but it failed a burn it was a auto long project and the best burn status was there i tried to have it at 480p so i could fit 41 min or 45 min files 30 of them if i tried twenty you think it would work
It is supposed to be able to do it. This has way too many bugs to where I can't really do anything with it until they fix some. And I haven't even tried to burn a Blu-ray yet, only AVCHD discs, so when I try to make one like you did I will probably have issues also. I am doing the same thing as you, trying to burn shows at 480 where I can have less discs being used.
Program seems to be working just fine; I converted 36 episodes, each about 24 minutes. End result 21Gb in AVCHD.
ROBERT46055: post conversion log.
