v1.6.0.27 Strange Behaviour...
mue.mat
Post by mue.mat »
Hello
After burning BluRay disc with several video files (--> is working perfectly) I try to play BluRay-disc first on my laptop. But unfortunately disc is playing only the first (of f.e. 8) video files.
I tried out with VLC media player and MPC-HC (all the same, just playing the first video file).
In older versions all the video files were "put" together to play the disc.
Playing the same BluRay-disc in BluRay-player, everything is working fine, that means disc menu is appearing and I can select the video file to play which I want.
Thanks for help and repairing the bug
mue.mat
Re: v1.6.0.27 Strange Behaviour...
VLC and MPC HC are not playing menu on BR.
They start from first file. You can advance to next or jump directly to any file with their own commands.
