Subtitle Problem
thiagogoettems
Subtitle Problem
Post by thiagogoettems »
Hi, i'm having problems with the subtitles, some phrases appears perfect, but the next line appears for 1 second and then disappears very fast, sometimes it does not appears. Happens with converted video.
SubRip/.ass subtitle, i can change size, color, subtitle location etc...
I'm using Nvidia NVENC, framerate is from 120 to 180, the others options are only getting 10 to 30FPS, maybe i'm doing something wrong?
Converting Mkv to Blu Ray 1080p.
Ch3vr0n
Re: Subtitle Problem
Post by Ch3vr0n »
doubt that's a CXV problem, you need to check the timing in the subtitle file. CXV only applies the times specified in the file. If the file says "show for 1 second" than thats what will happen.
Desktop: Project Phoenix
