Hello - Great product, thanks for the support you're providing.
I was wondering though if you had any suggestions on how to download videos from RetroJunk . com. VSO used to work with this site but it seems they changed their player and now videos are no longer detected.
I can't paste links unfortunately but if you click TV then Commercials from the menu it should take you to videos area.
Please let me know if you have any suggestions - Thanks!
Video detection issue
Re: Video detection issue
it uses the SSL protocol that will soon be supported:
http://forums.vso-software.fr/https-ssl ... 18841.html
Look for help on similar topic, but on another content provider
Same broadcaster and VSO Downloader works well in one part of their website
etv.err.ee/v/meelelahutus/ringvaade/saated/51227407-7545-44f0-beb1-ca46ab9f9857/ringvaade
and for some reason is not working for this site
etv2.err.ee/v/sport/saated/396151a7-643a-48f8-9aa5-cf4f139ae41a/seb-tallinna-maraton
In browser I can watch both videos, VSO Downloader's Network driver is WinPcap
What is the difference for VSO Downloader and what is your recommendation to enable downloader for etv2... part?
And once again thank you for the good tool!
sorry but the second url uses a different protocol that is not yet supported, we plan to support it but not now.
Thank you for answer! Can you tell what is the protocol used in 2nd link and do you have any estimation when will it be covered in the next VSO releases?
The next major release version (5) will support the HTTPS that is a big part other protocol will be implemented as soon as possible but I cannot give you a date.
So "watch the space!"
Thank you! Look forward!
