v1.3.0.24 problems
dragnil
v1.3.0.24 problems
Post by dragnil »
I've just installed the latest version under Win 7 and I'd offer two comments.
1. I may be wrong but I thought that in previous versions I could change the order of movies after loading then just by dragging in the left hand window. Certainly can't now and if it's never been the case then could this be considered as a feature request please?
2. It's now impossible to close the programme without saving the project. There is no choice, "Do you want to save" or similar, please restore the choice to be able to leave without saving the project. Hope this helps.
David
Re: v1.3.0.24 problems
1) was once possible in and older version (maybe version 4) of ConvertXtoDVD, but was not possible in ConvertXtoHD we will try and add that feature back.
2) in the default settings, in the general tab, click the button "reset confirmation dialogues" and this will resolve that problem.
