Hi guys,
I am really battling to understand something here…
I have downloaded a tv series (Cold Case) from the internet.
I have noticed that the video scenes are very jerky. I have realised that the files are all ntsc files.
How do I convert the mp4 ntsc files to pal mp4 files?
NTSC to Pal
Re: NTSC to Pal
It would be best if you post your conversion log in the forum, you will find that here:
C:\ProgramData\VSO\ConvertXtoVideo Ultimate\1\Log
Unless you are converting to DVD output or Blu-ray, the framerate will be the same as the source file.
You can create a custom profile of course and specific the container, the codecs and the video framerates...
Re: NTSC to Pal
Hi Clair,
Yes i have created my own profile, am i correct in saying that if i change the "Video Framerate" to 25, this will be PAL?
Re: NTSC to Pal
yes
Re: NTSC to Pal
Thanks Claire,
I'm starting to understand this now
