Dowloading videos from streamhoster?
m4dh4773r
Post by m4dh4773r »
I once used VSO downloader and saw it download videos from streamhoster a couple of years ago.
So when I needed to do that recently it was my first port of call, however after purchasing the unlimited version to make sure I had all functionality, it is not letting me.
What happens is it instantly detects the video, then says download error (in the logs it says no fragment available) ,then after a few seconds or so less than a minute another thing gets added to the download list saying it is Seg1 Frag1 and every so often a new one gets added, but each of these then shows a conversion error which in the logs says because resulting file is too small.
I really would like to be able to get this to work as there are some important videos I would like to download so I can watch them offline for something I am studying.
Can anyone offer any suggestions?
If not I may have to get a refund for this product and try and find another that does work. :(
Re: Dowloading videos from streamhoster?
If you could write to VSO technical support and provide the a url that you have this problem with:
Make sure you have tried with the latest version.
Posting your problem in the forum is fine, and you can add the url here too, but if you want to talk about a refund you need to contact VSO directly for that, this is just a community board.
m4dh4773r
Post by m4dh4773r »
This is the log file I added spaces in the urls in case the post got blocked for having urls in it
Code: Select all
23 Oct 11:07:10 | URL: ht tp : / /1-fss24-s0.streamho ster. co m/hypnosis/_definst_/mp4:AHAGuestSpeakers/AHA-Jenna-EnergyHealing.mp4/manifest.f4m
23 Oct 11:07:10 | hds (4 event(s))
23 Oct 11:07:10 | no fragment available
23 Oct 11:07:10 | Starting HDS downloader
23 Oct 11:07:10 | download (0 event(s))
23 Oct 11:07:10 | conversion (1 event(s))
23 Oct 11:07:10 | Conversion profile selected: Generic video@MP4 - H264
23 Oct 11:07:10 | renamer (3 event(s))
23 Oct 11:07:10 | referrer title (2 event(s))
23 Oct 11:07:10 | Referrer Web page title is empty
23 Oct 11:07:10 | referrer: ht tp : / /content.strea mhoster. co m/player/hypnosis/AHAGuestSpeakers/AHA-Jenna-EnergyHealing.mp4?autoPlay=1&showBuffering=1&showPlayPauseBtn=1
23 Oct 11:07:10 | conversion (2 event(s))
23 Oct 11:07:10 | temporary (0 event(s))
23 Oct 11:07:10 | original (0 event(s))
23 Oct 11:07:10 | download (2 event(s))
23 Oct 11:07:10 | temporary (2 event(s))
23 Oct 11:07:10 | File name changed: <unknown_file_name> replaced by <63581281630347>
23 Oct 11:07:10 | Extension changed: <ext> replaced by <part>
23 Oct 11:07:10 | original (2 event(s))
23 Oct 11:07:10 | File name changed: <unknown_file_name> replaced by <AHA-Jenna-EnergyHealing>
23 Oct 11:07:10 | Extension changed: <ext> replaced by <mp4>
m4dh4773r
Post by m4dh4773r »
Just to add, I have the latest version installed I have rebooted after install and I am still having the same problems.
Benjamin
Post by Benjamin »
as reported the HDS protocol has no fragment available which means it is a secure HDS stream (not yet supported).
