Latest CXHD beta version -
No beta version
Latest official version on ConvertXtoHD product page :
version 2.0.0.17 http://www.vso-software.fr/products/convert-x-to-hd/
Please post bugs found in this new version here in this thread.
Change log:
see https://www.vso-software.fr/products/co ... istory.php
ConvertXtoHD - 1.3.0.42 (Released 2015-12-18) [ View Issues ]
- 0010516: [Suggestion] When clicking on Output & Menu Changes, open the settings in Output or Menu Options (cedric) - resolved.
- 0010774: [Bug] when converting to avchd usb, default selected item needs to be a blank item so forces user to select correct usb in list (cedric) - resolved.
- 0010514: [Suggestion] Identify which version in the uninstall Program (cedric) - resolved.
- 0010802: [Bug] Use of rotate function in titleset give bad thumbnails in preview (cedric) - resolved.
- 0010456: [Feature Request] new default value: output format, video resolution should be "automatic -based on input resolution" rather than 720p (cedric) - resolved.
- 0010770: [Information] Increase video bitrate limitation to 30Mbit/s for software encoding (cedric) - resolved.
- 0010726: [Bug] Cannot assign a nil to a TVsoGraphic (cedric) - resolved.
- 0010757: [Bug] My video card get's detected, but cannot find any Acceleration Methods (Windows XP) (cedric) - closed.
ConvertXtoHD - 1.3.0.41 (Released 2015-11-27) [ View Issues ]
- 0010445: [Bug] bad preview and conversion of pcm audio file (cedric) - resolved.
- 0010651: [Bug] Low video quality in preview after maximizing the main window (cedric) - resolved.
- 0010649: [Bug] regression setting "merge subtitle into video if only one present" does not work (cedric) - resolved.
- 0010646: [Suggestion] Use RGB colorspace for menu rendering (avoid artifacts & give better quality) (cedric) - resolved.
- 0010601: [Bug] menu editor - green line artifact when changing background image (cedric) - resolved.
- 0010615: [Bug] snap_mm_cluster_tag in treeview (cedric) - resolved.
- 0010633: [Suggestion] Use panscan fit method for menu thumbnail rendering (instead of letterbox) (cedric) - resolved.
ConvertXtoHD - 1.3.0.40 (Released 2015-11-13) [ View Issues ]
- 0010584: [Bug] problem with background image of "default, simple menu" (cedric) - resolved.
- 0010579: [Bug] changing font color to custom value causes font color to show as black (cedric) - resolved.
- 0010576: [Bug] menu background has black borders (cedric) - resolved.
- 0010575: [Bug] the borders of the title icon images are incorrectly positioned. (cedric) - resolved.
ConvertXtoHD - 1.3.0.39 (Released 2015-11-09) [ View Issues ]
- 0010567: [Bug] app minimizes to taskbar alone and doesn't open again, must close through task manage (cedric) - resolved.
- 0010548: [Bug] Bad aspect ratio of videos/pictures in menu thumbnails/background (cedric) - resolved.
ConvertXtoHD - 1.3.0.38 (Released 2015-11-07) [ View Issues ]
- 0010545: [Bug] Burning process doesn't start (cedric) - resolved.
[2 issues]
doctorhifi
Re: Latest CXHD beta version - currently no beta
Post by doctorhifi »
I have the latest version 1.3.0.38 and have the following major problem:
I cannot change any of the settings. When I attempt to change a default setting the program window disappears. It shows up in the system tray but I cannot bring it back on screen no matter what I try. Right clicking on the system icon gives no options. Oddly enough, I seem to be able to convert a project but I am am unable to burn a converted project to disc as I cannot change the settings to the proper disc drive.
I cannot use the software as it stands.
I have no such issue with any other software on my PC.
Please advise
thanks
Dell XPS8700 running Win 7 64 bit, SP1 (fully updated)
24GB RAM
NVidia GTX660
JAL
Re: Latest CXHD beta version - 1.3.0.40
Post by JAL »
Since build 40 there are three double crosses at the bottom of the screen. Is this a bug or do I have to change a setting?
thanks for your fast report - a new version was published (same version number) and if fixes this problem so please download again with your browsers cache cleared.
slee02
Post by slee02 »
Latest v1.3.0.40 has a bug...
Every time I open the program the left side EDITING PREVIEW pane is open...even when I click arrow to close (minimize)....before versions would remember not to open it back up every time I close and re-open the program....
This started in convertxtodvd and convertxtodvd, but not convertxtovideo (i dont think latter has ever had EDITING PREVIEW window pane).
I appreciate your work and all fixes that you do...
